20 Most Recent Sony PSP-2001 Questions & Answers
Psp wont charge or tunr on
Did you put the battery back in? Just checking. This sometimes happens with the PSP's. The charger it's self looses the ground. Try plugging in a car charger, or use a charger that will charge the battery out of the PSP.
7/13/2014 7:30:46 AM • Sony PSP-2001 • Answered on Jul 13, 2014
Not charging and will not turn on
My son's PSP 2001 had the same problem if it was not in a hard case--the battery wouldn't charge and the PSP would not turn on. All we could figure was that something inside the battery area was loose and the snap-on case held the battery in place better. Try putting the battery in and holding the battery cover on firmly with your hand. If it charges and/or turns on while you're holding it like that, you might want to buy a case to sort of hold it together better. I think they loosen up over time and useage.
1/14/2014 2:27:06 PM • Sony PSP-2001 • Answered on Jan 14, 2014
Does not play unless on charger
Battery needs to be replaced!!!!
12/9/2013 6:59:27 AM • Sony PSP-2001 • Answered on Dec 09, 2013
Schematics diagram EADP-220BP A
no answer
3/21/2024 5:47:11 PM • Sony Video Game... • Answered on Mar 21, 2024
tip
Sony Playstation 1 replacing the power unit
Before you start make sure that the console is turned off and unplugged before you begin the process. This is for the 1001 model types. With the 5501 and the 7001 and for the 9001 the process might be slightly different. Step one: Open up the PS 1 console with a Phillips head screw driver and turn the console upside down and remove the 5 15.8 mm-long Phillips #1 screws. Step two: While holding the top and bottom halves of the console together turn the PS 1 console back over. Lift the top cover straight up to remove it. Step three: Unplug the power supply and then gently pull out the power supply cable straight up and out of its socket on the power supply to disconnect it. Step four: Now remove the power supply and then remove the 2 14 mm-long Phillips #1 screws securing the power supply to the bottom of the case. Step five: Lift out the outer edge of the power supply slightly, and then rotate the whole entire power supply away from the small clip on its inner edge to remove the power supply. To reassemble your PS 1 console back together follow the above steps in reverse order. Compare your new replacement part to the original part You might have to transfer the remaining components or remove adhesive backings from the new part before installing.
2answers
Psp
Yes, you need a software to convert a video file to a video format that a PSP supports which is MPEG4/M4V you can check this link for a sample of PSP video converter http://www.pspvideo9.com/
Hope that helps...........
2/3/2021 7:08:58 AM • Sony Video Game... • Answered on Feb 03, 2021
Can a Sony PlayStation 1 disc be faulty then and not work at all ?
Yes it is possible for a PS 1 disc to be faulty and not work at all. I had that problem with one of my PS 1 disc's was not working so I had bought a second disc of the same game for my PS 1 console and it was working. Try buying a new game disc to see if it works or not if it works then then it was just a faulty disc if it doesn't work at all then your PS 1 console is having a problem with the laser and the lens and the disc drive that needs to be replaced. If it is working on a different system then it could be your PS 1 console. Try a new disc and see if it works first.
10/23/2020 9:52:05 PM • Sony Video Game... • Answered on Oct 23, 2020
Sony playstion 2 Fat scph 30003 - no picture, no sound
There's an option says something like "Audio out" and you can set to Optical or Component (I don't remember quite right), you could try that. If that doesn't work and the video comes fine out of the composite cable and the audio out of the optical. Check the cables...
7/24/2020 10:31:13 AM • Sony Video Game... • Answered on Jul 24, 2020
2answers
I have a sony blu ray player that I cant get to work with net flix
You need to go online via PC or laptop or tablet to register your device.it must be using the same router.once your device is connected at the sane time as your registered device you can enter the code into the blueray or screen on device.this will allow the blueray to run via internet.I think I am right in saying earlier sony bluerays from Europe/Uk do not run netflix only amazon. The American ones do.
3/13/2020 3:12:34 AM • Sony Video Game... • Answered on Mar 13, 2020
I have Sony mini Wi-Fi system R v 6 and have an error c 81 how can I remove it
Editing two simple operating system settings can solve this connectivity problem.
2/13/2020 9:23:25 PM • Sony Video Game... • Answered on Feb 13, 2020
Ps2 multitap
It's the multitap, yours is designed for PS1 games, and PS2 and PS1 games require different multitaps. You have to buy one specifically for PS2.
7/27/2019 12:12:51 AM • Sony Video Game... • Answered on Jul 27, 2019
2answers
All my and just my fifa soccer games at half time
its probly the game disc mate. its had its day. u can send them to shops that fix disc 4 u, 4 a cetain price. if it still dont work then only option is to by new fifa games.
6/13/2019 9:56:40 AM • Sony Video Game... • Answered on Jun 13, 2019
How to solder a loose wire from a psp go sony charger
First you will need a pin out of the adapter. Tools you will need are. 1: Solder with rosin core thin solder would be best 2: Soldering iron lower watts the better 3: Flux to clean the surface you want to solder to 4: Sponge to clean the tip of solder iron If you don't have any of thous supply's it would be cheaper to buy a new cord. Also if you don't have vary much experience soldering i would also recommend getting a new cord for the fact you can cause more damage than good. To get the solder iron ready you need to heat it up. Once it is hot enough to melt the solder apply the solder to the tip and let is set there until you want to solder. You have to clean the tip off with a wet sponge but not soaked in water just enough to get it wet. Every time you go to solder Clean the tip off and apply fresh solder to it not a lot just enough to cover the tip when you want to solder. When you go to store the iron apply a small blob of solder to the tip to keep it from oxidizing. Strip the wire shielding off a bit longer than the size of the contact you want to solder. Twist the wire and put flux on the surface you want to solder and tin them. Tinning the wire is just applying a small amount of solder to the wire as to hold the strands together and make it easier to transfer the heat and solder to the contacts. Now mach the pin-out to the weirs to the contacts and put flux on the contact you want to solder to. Clean the surface by applying flux to it.The surface will be oxidized and will not let you transfer heat or solder to the surface. The key to soldering is to use the right amount of heat , solder and time you hold the iron to what your soldering to. You want to make sure you touch the wire and the contact you are soldering to as to transfer the heat to both items at the same time to make the solder flow. Put the solder wire to the tip of iron that is touching the wire and contact and not on top of the iron tip. Any time you apply heat to solder joints you want to use flux to keep them clean and free of oxidized material. After you solder check the solder joints for cracks, uneven and dull surface. You want the solder to look as shiny as possible and smooth. If it looks like it has waves or holes and cracks it means you have a cold solder joint and must reheat and apply flux with a small amount of solder to fix it .Here is a link to help you out this is not my site and full credit goes to the owner of site. How To Solder Soldering Tutorial Also put a link to a new cord if you decide you want to get a new one. Here is a link that may or may not help with the pin-out. Also not mine it should credit the poster on the forum as he did all the work i just found it PSP Go Cradle mini USB Tutorial with Partial Pinout PSP Go Acidmods com
5/28/2019 8:52:59 AM • Sony Video Game... • Answered on May 28, 2019
I cant start my ps4
may be you need cdkeys for the game, or your consoles do not work, you need find what prolem actually is, if need cd keys you can have a view on https://www.m8x.com, if your console do not work, you should repair it, if you need FIFA Coins, FUT Coins or FIFA 19 Coins, you can have a view on https://www.fifacoin.com
2/21/2019 2:06:11 AM • Sony Video Game... • Answered on Feb 21, 2019
My Sony mgongo 1000wats 4.2ch is not playing music it's reading system update on the screen
can I buy fifa 19 coins from https://www.fifacoin.com? I only get 5$.
1/4/2019 9:33:43 AM • Sony Video Game... • Answered on Jan 04, 2019
I need a cool online gaming name
Hello my friend,if you like first person games try call of duty modern warfare 2,if you like strategy games try warhammer dawn of war 2 or command and conquer 3.If you like role playing games try lineage or world of warcraft.Personally i love call of duty
11/26/2018 6:56:32 AM • Sony Video Game... • Answered on Nov 26, 2018
|Invalid file format" at my sony psp mp4 gameplayer
Idiots, Idiots everyewhere
10/3/2018 12:45:17 PM • Sony Video Game... • Answered on Oct 03, 2018
How can i get cheats in the game?
Online, google the game and console details and add cheats.Generally a list of sites will give cheats for the game selected.Follow the commands
7/30/2018 7:50:22 AM • Sony Video Game... • Answered on Jul 30, 2018
Sony PSP-2001 Logo
6 questions posted
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Video Game Consoles & Games
Most Popular Question
psp wont charge or tunr
  • Video Game Consoles & Games
