Symbol LS 2208 Barcode Scanner Logo
Posted on May 27, 2009
LS2208 scanner not returning for multiple scans
I have the LS2208 scanner in its dock so its on all the time, the problem is I cannot scan multiple items without using the tab key or mouse to return the curso back, is there a solution?
regards: rick
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
624
Points
My ls2208 scans a barcode and all it does is beep beep beep. when i first got it the scanning light didn't go on. tried it at a friends computer and it worked everytime. i came come and downloaded all the computer upgrades and finnally got the light to come on. any help? i'm just looking to read barcodes off baseball tickets.
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Jul 03, 2009
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
27578
Points
53
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
After scanning it is automatically not going to the next line
Symbol barcode scanners by default do not add a return after a scan. You need to program the scanner to add a suffix.
Download the manual from Motorola/Symbol here
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf&sliceId=&dialogID=219596399&stateId=1%200%20219598121
-Print Pages 224 and 225
-Scan the Barcode "Scan Options"
-Scan the Barcode " "
-Scan the Barcode "Enter"
Scan a barcode
3helpful
How do I get my scanner to go to the next line/box when using Excel?
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
1helpful
2answers
Reversing first 2 digits of barcode
Attached are the programming barcodes for the LS2208 solve this problem. Print the attached file and scan the barcodes in order 1-10. This will only work on a LS2208. If you scan the Set Defaults barcode it will erase this programming rule.
there is a document you will need to scan to do this, if you want to send me an e-mail i will send you the document
[email protected]
2helpful
I use usb base ls2208 my problem is every time
Hi, to make the scanner automatically hit enter print and scan the barcodes Scan Options, Data Suffix, and Enter from Adobe pages 222 and 223 of 342 of the LS2208 Product Reference Guide.
4helpful
When i scan a barcode why do i have to push enter?
Go to http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201bpdf&sliceId=&dialogID=111756507&stateId=0%200%2011492385
This is the quick start guide for the LS2208. On the first page you will see a section titled Carriage Return/Line Feed. Scan these three bar codes from top to bottom. That's it.
I have a ls2208 symbol scanner that need to scan code 39.... The example below is return when I scan the following information. It seems to be do stange thing with the first 2 charecters. Can you help?...
Your scanner is set up for full Ascii mode.
$B = CTRL B
%I = >
Re-program to enable "Code 39" and disable "Code 39 Full Ascii"
In Code 39:
$B = Control key on
%I = Tab
Hope this helps.
11helpful
2answers
2helpful
Symbol LS2208 RS232
Go to the LS2208 quick start manual scan the "Set Defaults" barcode and it will return the handheld to factory default.
2helpful
Scanner Symbol Ls2208 keyboard not work
The scanner does not detect the keyboard host on power up and is locking up your keyboard. The IBM PC/AT host type barcode must be scanned the first time it is setup. The barcode is on Adobe page 56 of 342 of the LS2208 Product Reference Guide. The scanner should start working immediately after the host type barcode is scanned.
Top Symbol Office Equipment & Supplies Experts
NOEL
NOEL
Ngoro
Are you a Symbol Office Equipment and Supply Expert? Answer questions, earn points and help others
