20 Most Recent Symbol LS 2208 Barcode Scanner Questions & Answers
3answers
Does LS 3578 ER SCANNER HAVE A DRIVER ?
it can work with ether of them mainly then driver is needed. so i hope that is the answer you wanted and please rate the help i have been to you.
THANK YOU!
5/20/2016 7:42:56 PM • Symbol LS 2208... • Answered on May 20, 2016
2answers
Manual carriage return necessary after scanning
With the Symbol scanners, they usually come with a sheet at least of scan codes to configure the scanner. One of those bar codes will have the option of not needing to manually hit the carriage return. What model scanners are they? You can probably find the codes from Symbol.
5/20/2016 7:32:24 PM • Symbol LS 2208... • Answered on May 20, 2016
2answers
Scan a single digit character
i have problem with when i goint to scan after 5 or 10 minutes after it disable, and then we go to connect and disconnect to work
5/20/2016 7:26:51 PM • Symbol LS 2208... • Answered on May 20, 2016
LS2208 - Is there a barcode I can scan to turn the
There is a continuous power and reduced power mode that can be enabled disabled via a bar code. See this link on page 51 - http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
6/13/2011 6:42:30 PM • Symbol LS 2208... • Answered on Jun 13, 2011
Having to hit enter after scanning an item
You would need to setup those three scanners correctly, the solution is described on the manufacturers website, please see http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=ADC-01244&sliceId=SAL_Public&dialogID=189660762&stateId=1%200%20189654426
8/27/2010 7:46:43 AM • Symbol LS 2208... • Answered on Aug 27, 2010
Scanner is Unable to scan initial 0 for EAN13 symbology
Please scan the barcode "System Character & Country Code
(< COUNTRY CODE> <SYSTEM CHARACTER> <DATA>)" from the manual at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=27078247&stateId=0%200%2027076181
8/26/2010 11:48:41 PM • Symbol LS 2208... • Answered on Aug 26, 2010
2answers
LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
3/14/2010 3:38:01 AM • Symbol LS 2208... • Answered on Mar 14, 2010
The LS 2208 scanner I am using will beep when idle
Clean the glass really well. Sounds like it's picking up a number when it shouldn't.
12/8/2009 3:25:46 PM • Symbol LS 2208... • Answered on Dec 08, 2009
I have a ls2208 barcode scanner and require it to
Plz Check your Bar code Sticker your Bar code Sticker is 99.99% is corrupted
8/17/2009 4:21:31 PM • Symbol LS 2208... • Answered on Aug 17, 2009
2answers
It just stopped working
My company installs ls2208s for our customers. Never had a problem until recently, one of our customers had three fail all at once. Upon calling Symbol (1-800-653-5350) I was told that there was "a bad batch." Apparently, wands manufactured around the end of Oct until Nov 2008 are bad. The company will replace the wands free of charge(make sure you save the stand and power cable as they will only replace the wand itself).
The manufacture date is on the label just above the trigger. Hope this helps.
5/8/2009 3:16:23 PM • Symbol LS 2208... • Answered on May 08, 2009
HR-150TM, HAVING PROBLEMS WITH % SYMBOL STAYING IN PRINTED CALCULATIONS SINGLE AND DOUBLE TIMES WITH THE NUMBER IN RED BEFORE THE % SIGN.
Please edit out all the shouting CAPs. Include full 'make model (what it is)'. There are 40,000 categories to choose from rather than 'Symbol Office Equipment'.
11/14/2023 3:17:45 AM • Symbol Office... • Answered on Nov 14, 2023
What does the IH symbol mean?
Possibly International Harvester. Provide more information concerning your question using the Comment menu, please.
11/13/2019 1:39:54 AM • Symbol Office... • Answered on Nov 13, 2019
! in triangle symbol of HP1320 printer flashing. Only light. Cartridge door closed. Troubleshooting says all is well. Print job goes to queue, then disappears as done, but nothing prints.
On the HP LaserJet 1320, the attention light is a generic alarm. It can mean out of paper, paper jam, paper misfeed, cartridge missing, or cartridge door open. You can try cleaning the pickup roller or changing the separation pad. You can find these maintenance steps in the user manual starting on page 73 (page 83 of the PDF). HP has the manual here: http://h10032.www1.hp.com/ctg/Manual/c00208215 . More guides are available on the product page: https://support.hp.com/us-en/product/hp-laserjet-1320-printer-series/410622/model/410624/manuals . Amazon has the separation pad available here: https://www.amazon.com/RM1-1298-HP-Separation-Tray-P2015/dp/B009SPB1H4 . Links to replacement pickup rollers are on this page. There are probably other sources for the parts as well. Unfortunately, it can also indicate that a part has broken from paper pickup unit or the door closed sensor isn't working. At my home when our LaserJet 1320 reached ~10 years old, we got this message and decided to replace the printer. It wasn't worth trying to locate and repair the problem when cleaning the pickup roller and paper path didn't work. I hope this helps. Cindy Wells
3/18/2019 6:45:27 PM • Symbol Office... • Answered on Mar 18, 2019
An orange sign is show on my printer what could be the cause?the forst symbol before the traingle sysmbol
You can try out some guide from here reliable-store they also provide live chat feature for instant help and it's very useful
3/12/2019 10:10:46 AM • Symbol Office... • Answered on Mar 12, 2019
My printer canonMF3010, its showing paper jam symbol , but there is no paper , how to solve this probelm
There will be 1 of the paper sensors that is jammed, so that the printer thinks that there is paper in the area. You will need to follow the paper flow and check that all the sensors are moving freely. I had a feather from a feather duster suck in a printer holding a sensor wiper open. took me ages to find the problem. Hope this helps
10/22/2018 2:42:06 PM • Symbol Office... • Answered on Oct 22, 2018
Symbol LS 2208 Barcode Scanner Logo
18 questions posted
Top Symbol Office Equipment & Supplies Experts
NOEL
NOEL
Ngoro
Are you a Symbol Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Symbol Office Equipment & Supplies
Most Popular Question
ls2208 barcode scan turn
  • Office Equipment & Supplies
