SOURCE: 1992 es 300 lexus heater is blowing cold
. Yes it could. some are vacuum powered, cable powered (mechanically) or electric powered. If the valve does not open. The hot water will not get to the heater core. It could also be the thermostat not opening.
SOURCE: How many O2 sensors on a 1997 Lexus ES 300?
according to the manual i have... it has three.... one in the exhaust manifold.... and two in the exhaust pipe..... slightly vauge on the exact location of the last two sensors... but looks like it is after the catylitic converter.
SOURCE: Lexus ES 300
Unscrew the gas cap, wait 30 sec and screw it back on making 3 clicks/cracks. Should be ok in a day or two.
SOURCE: location of fuel filter on 2000 lexus es 300
The fuel filter on the ES300 is located under the hood, on the driver's side, by the fenderwell.
SOURCE: HEATER NOT WORKING IN 2001 LEXUS RX 300
you most likely have a bad airmix servo. this happens alot on these. they are expensive to replace too.
