Toyostove Laser 30 will no ignite or do anything, it just reads error code : EE 22 . this is onle 1 yr.old , had little use, any solutions?
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Unable to locate a Blower Motor Assembly for a laser 55. Can you use one for a laser 56. Been told can and then told can not.
The laser 55 appears to have no power. Could the circuit board go out completely?
