To remove the battery from the back of an Oasis watch, you will need a small flathead screwdriver or a coin.
- Locate the battery cover on the back of the watch. It is typically located at the 6 o'clock position.
- Insert the screwdriver or coin into the notch on the battery cover.
- Gently pry the battery cover off of the watch.
- Remove the battery from the watch.
- If you are replacing the battery, insert the new battery into the watch, making sure that it is oriented correctly.
- Replace the battery cover by aligning it with the watch and pressing it into place.
If you are having trouble removing the battery cover or if the watch has a different type of back, you may need to refer to the manufacturer's instructions or consult a professional watch repair service. It is important to handle the watch carefully to avoid damaging it.
