SOURCE: thread on bottom, bobbin thread loose
Sounds as though you've misthreaded the upper tension. The best way to verify this would be to thread your machine, lower the presser foot on to the material. Now try pulling the thread through the needle. (Assuming your upper tension dial is set to a number greater than one). You should feel resistance. Should you not feel resistance, rethread your upper tension.
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
thanks.
SOURCE: I have a singer futura ce-250/ce-350 machine.
I have been sewing for quite some time on other machines. I assumed I knew all that I needed to do and I have the same problem, bunching undeneathe. I found out my problem was twofold. One when you thread the top part - you should pull the thread back and forth in the top thread guide. (#1 in the manual page 6). The second thing was the curly tail in front. It really needs both of these. I hope this helps you. Made me feel really inexperienced. I actually pulled out the manual.
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
