Just bought a 88 Toyota Corolla that had been sitting for about 10 months. I noticed it had a new fuel pump and filter. The car started with a little starter fluid, and idled fine for about 10 mins. Then it died and wouldn't start without more starter fluid. I drove it out of the garage and let it run for about 10 mins more, then it died again. Then when I got it started (with more starter fluid) and gave it gas, it sputtered and backfired through the carb. After letting it sit for a couple hours I was able to get it started, and it ran for about 5 mins then died again. I looked down into the carb, and it is getting fuel. I can't get the engine to run for more than 10 mins! I tried spraying carb cleaner on and in it. No help. All the vac hoses seem to all be connected. I don't think it's a timing problem because when it is running (for about 10 mins) and I give it gas it revs and sounds fine. Only after 10 mins does it start to shake, sputter and die. I'm going crazy trying to solve this problem! Can anyone help?
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
have you tried to change your sparkplugs?
It sounds like you have a carb and gas tank full of water. You may have to drop the tank, drain it, rinse with methyl hydrate and refill. Throw a quart of methyl hydrate in the tank when you refill it to try and dry the carb out. Oh, new fuel filter as well.
