My son received this transforming radio control car for Christmas and the controller is 49mhz and the car is 27mhz. the numbers on the box are 1639834 (25716) On the box the 27mhz is checked off.In the section that says BOX CONTAINS THE FOLLOWING FRQUENCY.
SOURCE: transforming radio controlled car will not work, I
There is supposed to be an on/off switch under the fin above the rear wheel but I can't find it. Hopefully, you can.
SOURCE: Where do you put batteries in transforming radio
There is a plastic latch that loosen with a philips screwdriver. Rotate the latch down and you should be able to rotate the top half of the back up.
