Dear PIETERM
Please find the following link to download the trial software for your device.
if you want you can purchase the software from same website
http://www.ptshome.com/download.php?ProductID=TracerPlus%20Std%20for%20Windows%20Mobile/PPC&Filename=tracerp_ppc.exe&ProductPage=windows_mobile_tracerplus.htm
Please try if this solves your problem.
Spice Prince
I'm not sure if you can trigger the scanner based on a web field but you can just enable the Data wedge software which will allow the scan to input anywhere you have the cursor. The scanner will be "active" all the time but won't actually scan until you pull the trigger. You can download the datawedge software from www.symbol.com.
You need to do something like this...
<script>
function enableScanner(enable)
var objGeneric = new ActiveXObject("SymbolBrowser.Generic");
if (enabled)
objGeneric.InvokeMETAFunction('Scanner', 'enabled'); /* Enables the scanner */
else
objGeneric.InvokeMETAFunction('Scanner', 'disabled'); /* Disables the scanner */
</script>
<input type='text' name='field' onFocus="enableScanner(true)" >
This package contains DCP v1.6 for MC9090c50 devices.
DescriptionGeneral Issues Resolved
Fixed memory leak problem in notify API
Set default date after cold
boot - 1/1/2007
Fixed issue in web browser
wherein the control which had focus prior to the browser's minimization
lost the same when the browser was restored
Fixed SDMMC driver
for potential SD card corruption
Added support for Simple Network Time Protocol (SNTP)
Fix for 'Adapter not available'
error
MC9090 specific changes
Support for new display panel on all 909x color configs.
Support for USB mouse
IDOCKIT v4.01.01.0 cab file included in application partition.
Fix for a silent .wav file producing a high pitched sound.
Wavelink TE 6.0.42.
Implemented the
IOCTL_HAL_GET_UUID.
Fix for download in Bgz format and download via SDcard
1.
9090c50BenDC010604.exe
Microsoft Windows 2000 or Windows XP Operating System
Download the 9090c50BenDC010604.exe file.
Double click the file.
Follow the install screen prompts.
9090c50BenDC010604
July 25,
2007
All the best,
Ben
