The subwoofer light is on but the light for both satellite speakers are not and i get no sound at all. the cables in the back of the sub are pushed in all the way. what to do?? thanks in advance
Make sure the triangles on the plugs are lined up when you push in the plugs!
Its not a problem, but all you need to do is push the pins at the back a little more...I know it feels like pins are all the way in, but they really aren't.
Push them in further...i thought mine were in all the way too until I read this post. After forcing them in harder than one would expect to have to the lights went on and the problem is history.
Forget everything mentioned above. You're problem is as follows ;))
http://rayholt.wordpress.com/2012/04/12/how-to-fix-jbl-creature-ii-speaker/
Same problem here, HELP! Very annoying.. happent from one day to the next. should i just use the warranty, or is there some secret to turning them on?
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer
speaker system designed and sold by JBL. The system is made up of two
satellite speakers and an omni-directional subwoofer. The speaker system
connects directly to a computer's available sound card output jack or a
laptop's stereo output jack. Occasionally, problems can occur with the
sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable
connections. Ensure the satellite speakers are firmly connected to the
matching jacks on the back of the Creature's subwoofer. The
connections are color coded and, in addition, each speaker connector is
shaped differently to fit only into one jack. Ensure the output cable is
firmly connected to the subwoofer audio in jack and the computer's
audio-out jack. Ensure the power button on the back of the subwoofer is
pushed inward. If everything is connected properly, the green lights
on the underside of the satellite speakers will glow.If there is
still no sound, tap the right-hand side audio-increase button on the
right satellite speaker until sound is heard. Also ensure there is audio
playing from the computer. Double check the lower right-hand side of
the window's main screen and look for a speaker icon. If the icon has a
red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
i have the exact same problem, all cables are in the entire way, but speaker lights do not come on, yet the subwoofer light does come on... any ideas>?
yes,same problem here...
blue light on the sub ok, and little sound, no lights on the satellites
and no sound. What is going on and is there a fix??????
Me too - never had a problem with the speakers, brought them to the US from Europe, and then the satellite speakers stopped illuminating and no sound is produced at all.
They were working fine and I loved the sound but one day I turned them on and after a few minutes the went silent. Power light on the woofer is on so the power supply seems to be fine but no lights on the sats, no sound anywhere. YES my power cords are pushed in all the way. Any other suggestions???
Speaker will not turn on, even though the JBL insignia lights up, but no other functions work either.
