Changed filter, won't dispense water or ice after going through filter reset on panel
SOURCE: Maytag refrigerator water dispenser not working
you may have dislodged a sensor or perhaps you may have blocked your water line somehow... im not sure about this specific model, but just try having a look at what you did and see if there are sensors around there.. and make sure u havent dropped anything in there wich may have clogged the lines... lets hope its not your solenoid that has gone, sounds unlikely though you never know
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator is not producing enough ice. I would advise to check and make sure that your water filter has a secure connection, if need be uninstall and reinstall the water filter to assure connection. Your filter should be changed every six months, if it is has not been changed recently I would recommend exchanging it.
If you continue to receive low ice production it could be an issue with your water line or water valve, I would seek assistance from a professional for proper diagnose and repair of your appliance. I hope this helps. -Matt
