Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator is not producing enough ice. I would advise to check and make sure that your water filter has a secure connection, if need be uninstall and reinstall the water filter to assure connection. Your filter should be changed every six months, if it is has not been changed recently I would recommend exchanging it.
If you continue to receive low ice production it could be an issue with your water line or water valve, I would seek assistance from a professional for proper diagnose and repair of your appliance. I hope this helps. -Matt
Hi friend, I appreciate your post!
I see your question is labeled under Frigidaire refrigerator, FGHB2844LF, and you are having difficulty engaging the water filter. Based off that model you should be able to push on the face of the water filter and slide the old cartridge out. First, to install the new cartridge you would need to remove the caps off of it. Secondly, using the alignment guide slide the new filter into the housing until it stops against the snap-in connector. Thirdly, push firmly until you hear the click which indicates that your filter has been engaged. Lastly press a glass against the water dispenser to verify no leaks are present at the filter housing. Hope this helps. -Matt
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
5 questions posted
322 Questions
159 Questions
143 Questions
42 Questions
