My speed queen front loader will not balance. it shakes even when there are no clothes in it when it spins.
Make sure the lags are solid to the floor. Any bit of difference will be exagerate when the washer spins. put a piece of paper under each of the front legs. While the washer is spinning try and pull the paper out. If you can pull the paper out with no problem, that leg needs adjusted to the floor more. If Ican help further, please let me know
THanks
Vic
You can remove the front lower panel and see if there are any of the shock supports broke. there should be three screws holding the panel on. Get me the model # and I can be sure.
I,m sorry but, this sounds like you might need a repairman so they can see exactly what is going on. It might have a tub out of place.
What I suggested are the most common solutions. Without seeing it, I am not sure what else it could be.
i have tried diff. size loads and it will walk away on some loads. i have installed 3/4 plywood to stiffen up the floor and its not helping.
model # ctsa0awn, speed queen. i have looked at them and they seem ok.i have taken the panel off the back and the one off the front. pulled and pushed on them and they will go back to the ori. pos.
Front load washers will shake if the load is not balanced. The more clothes the better.
Small loads do not work in a front load washer.
