Rolex Daytona 116518 Wrist Watch Logo
A
Anonymous Posted on Dec 19, 2013
Gucci watch stopped working
Automatic movement watch stopped working
ibewjm
Level 2:
Habit-Forming:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 105 Answers
  • Posted on Oct 08, 2018
ibewjm
Expert
Level 2:
Habit-Forming:
Cheetah:
Answers
105
Questions
0
Helped
51578
Points
169
The watch needs to be services. Any good repair shop can do this work.
1helpful
I have a Gucci watch with the model number 3605 L on the back but I don't see a serial number how do I find out if its real
Open it up and see what movement is inside, Gucci Buy their movements, as they are NOT watch makers but a fashion designer. I would expect to see an ETA automatic 2836/2 or similar. The ETA is a Swiss made movement, ETA supply movements for many good watch brands, such as Tag Heuer, early Breitling, Raymond Weil, Fortis, Ebel & the list goes on. Very easy to work on and spare parts are easy to obtain. Great work horse movement is the ETA, hence why everyone else uses them, not just Swatch.
Not sure your watch would have a serial number, not all watches have them. Just because you can’t see one or it doesn’t have one, it doesn’t mean it’s fake.
If you pop the back off, take a photo of the movement and send it to me at [email protected] or if you can place it on here, do so, but I’m guaranteed to see it if you email it to me.
Gucci watches are around £400/£600 range, so should be a good solid watch.
Does it sound solid when you shake it? It shouldn’t squeak or rattle too much at that money. The crystal should be AR coated (anti reflective)
Also use a magnifying glass to look at the dial for imperfections, there should be none. QC at Gucci is tight, so look carefully at the dial.
Hope this helps
What's the proper battery for my Gucci 6400L?
Ensure the watch battery is dead. A Gucci watch is not exactly a cheap trinket, thus the battery should have a fairly long lifespan before requiring a replacement. Once you see the hands of time stop on the face of your luxury item, you can be sure it is time to purhase a new battery. The typical cost for a new battery starts at $50. There are three categories for a Gucci watch: Automatic watches, quartz watches, and bracelet watches. Depending on the type, you will need a battery that suits one of these classifications. Batteries for Gucci watches can usually be obtained on any discount/surplus website (e.g. eBay, batteryright.com, or the actual Gucci store).
Read more : http://www.ehow.com/how_4966607_change-gucci-watch-battery.html
Jul 03, 2014 • Watches
1helpful
Rolex Sumariner with Date submersible to 300metres
your submariner is an automatic movement that needs to be serviced every 3-5 years to replenish the oils and to stop any wear or tear on the movement the regulation is part of the service
2answers
What is the proper battery for my Gucci Watch model 3000
Don't be cheap!!!! Go to a reputable jeweler. Most of them are very clued up on these watches and they will give you the correct information. There are many types of batteries and sizes of batteries. There are also a variety of movements for battery watches. If the wrong battery is put or forced into the watch you can do damage to the watch and then will become more expensive to fix!!!
2answers
How can i tell a fake from authentic?
mcdevito75 here, Best Bet is to look for a small watch repair shop in your area, they can authenticate your Gucci watch for you. If you can, remove the back cover of your Gucci and record any and all numbers and other info off the watches movement itself then check online at Gucci.com. If your not familiar with watches, specially Gucci an expensive watch let a small watch repair shop remove the back cover and give you all info needed to authenticate the watch.
1helpful
Cannot get the analoue display to work on my gucci i-gucci digital watch. can you advise please
Check out if your watch has two separate batteries - one for digital and another for analogue movement.
If it does, replace analogue battery. If it does not - you will need help of a watchmaker.
Rate, please.
1helpful
Got it wet
You have to open the watch, take out the movement, take out the battery, dismantle whole movement and dry it in special watch cleaning machine. Do not hope the moisture is affecting the look of the watch only (misty) - it is definetely affecting movement and battery as well and your watch may stop for good after some time.
My advice - find your nearest watch repair shop and ask to dry it out.
Even if the visible mist inside watch has gone, there are still water in the watch movement.
Rate me, please.
Top Rolex Watches Experts
NOEL
NOEL
john h
k24674
Are you a Rolex Watch Expert? Answer questions, earn points and help others
