Sir, I want to take out my photos to my pc but my i733 digital camera software is not supporting my system please help me out
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
SOURCE: Where can I find drivers?
Try this link at their website
http://mycusthelp.com/Polaroid/_cs/AnswerDetail.aspx?sSessionID=&aid=4690&pg=0&lstFilter_a=-1&lstFilter_b=-1&lstFilter_c=-1&txtCriteria=&optcond=2
SOURCE: polaroid i830 driver
same **** here. cant find my disc. Looking for somewhere to download the driver? Whats up with this hale????
SOURCE: Polaroid i733
My pictures always come out very dark. I'm not sure if the settings need to be adjusted. I tried adjusting the color but, the pictures are still dark. What should I do?
SOURCE: need software and driver for ion digital camera
This type of camera is mostly designed and made in China, and is usually unsupported in vista. For XP you can try installing the driver came in a CD along with your device.
You can also try for alternate way.
If the camera uses a memory card, you can buy a card reader.
Then you do not have to install any of the software that came with the camera.
Any store that sells digital cameras will sell memory card readers.
Prices run from $10 to $20.
You can attach the card reader to your computer USB port and Vista will recognize the reader as being a new hard disk. Vista will load the correct drivers.
After that is done, install the memory card (full of photos) into the card reader.
Then you can use Windows Explorer or My Computer to find the new hard disk (which will be the memory card). Use drag and drop to move the photos to your computer.
