Replaced the water filter and it improve however after a 2 weeks the flow is very slow again. the fridge is only 2 years old
Try replacing the filter again, If it works again then you might want to think about putting some sort of water softener system in your home
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
SOURCE: Very bad smell coming from my Samsung refrigerator
most refrigerators have a small drainage hole leading from the inside rear of the compartment to an overflow container behind the unit, pull the unit away from the wall and check if the liquid in the container has become stagnant, if so simply clean it out and run a small amount of bleach down the hole to disinfect the tube.
hope this helps.
I replaced the water filter and the water pressure went back to normal gain. I thought the problem was fixed!!; however 2 weeks later the water pressure is very low once again.
