When I push the on/off button the camera won't react. I use my camera all the time and the last time I put it away in the case, I heard the sound of it opening up so I took it out to look at it and it was closed. 2 days later I pushed the on/off button and the lens wouldn't open
SOURCE: coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
SOURCE: Dropped the Camera, Lens is stuck open
I already tried posting this but I think it falied. Just in case, here it is again!
I just now fixed my own Nikon S220 (very similar to 210) which suffered the same fate as yours. However, I laid my camera down on a cushioned foot-rest (you could use a couch cushion or pillow on a table) with the lens facing UP, pressed down on both sides of lens front gently yet firmly, and BAM, the lens went back in all the way. I turned the power back on and the camera is good as new (except for the small dent from the fall of course).
I suggest you try this before spending $100 on repairs and/or buying a new camera!
SOURCE: Push on button. Camera turns on, lens pops out.
Most of these kinds of errors come as a result of some kind of impact, sand or dirt exposure, possible water damage, or some other problem with the lens.
There is a possibility that the lens is off track.
Try pulling or pushing (not too hard either way) and see if it may be off track and return it to the correct setting.
Since it is not working anyway, try the above a few times and then test the camera to work right.
I have fixed more than one with similar (off track problems) and they worked good after wards.
Worth a try.
If nothing works, I suggest to sell it (include all that you have with the sale) on a site such as Ebay as parts, or as is repair. It should bring something like $20.00 to $50.00. The LCD is worth something over $15.00 alone. The other parts of the camera has value to those who repair cameras.
SOURCE: CoolPix L 18 Problem
It probably can be fixed if you can get to them. Most cameras' lens assemblies are replaced as a unit when they go bad, it's just not cost effective to spend the time to tediously take them apart, repair the problem, and reassemble. You sound pretty mechanically inclined to have fixed the gears, so I would say you could probably pull this off if you try. Good luck, it's not what most people should try at home!
Testimonial: "Thank you a lot, have a great Easter "
SOURCE: nikon coolpix s210: when i push the
the lens motor that drives the lens too & froth must be changed to get it working properly again, u need to go to the local service center, the will help you out. u can give me your location & i can help u with the nearest service center.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
