Precor C954i Commercial Treadmill Logo
A
Anonymous Posted on Dec 03, 2013
Treadmill will not run
Will not power up
My treadmill run for a few second and stops
There could be several reasons why your treadmill is stopping after running for only a few seconds. Here are a few things you can check:
  1. Power source: Make sure your treadmill is properly plugged in and that the power outlet is working.
  2. Safety key: Ensure that the safety key is in place and fully inserted into the console. If the safety key is not properly inserted, the treadmill will not function.
  3. Motor: If the motor is not working properly, the treadmill may stop after running for only a few seconds. Check the motor by turning the treadmill on and listening for any unusual noises.
  4. Belt: A loose or worn-out belt can cause the treadmill to stop running. Check the belt tension and replace the belt if necessary.
  5. Control board: If the control board is malfunctioning, it can cause the treadmill to stop running. Check the control board for any signs of damage or wear.
If you are unable to diagnose the issue, it may be best to contact a professional to come and take a look at your treadmill.
Reebok gt60 treadmill won't run, but has power.
https://www.sportsrec.com/351318-how-to-troubleshoot-my-reebok-treadmill.html
If the electrical outlet works, unplug the treadmill and check the power cord for damage. Replace the power cord if it's damaged. If the power cord is okay, check the circuit breaker switch on the treadmill and reset the circuit breaker switch if it's tripped.
https://www.searspartsdirect.com/diy/symptom/treadmill-repair/1234711/won-t-power-up/tm520420
T700 treadmill console not working. Plugged in & worked; reached 3mph & removed safety magnet. Console went black; won't come on. Power switch lights up; lower board led light shows power on.
The treadmill will not run if you remove the safety magnet. Replace the safety magnet and reset the treadmill. Should start working again.
Thanks.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
I have a problem. Every time I try to run my treadmill the motor runs for roughly 2 seconds and then turns off. The power is still on, however, but the treadmill only runs in short bursts. How can I f
If it stops but you can still hear the motor running then I would check the belt tension. The force of you running could be causing the belt to stop but no the drive.
Irun treadmill not working- blank screen, belt not running but power light on
1) adjust the REED swtich, clean, and tigh the wires connector.
2) After you did the adjustmente RUN the software calibration for diagnose, troubleshooting, and fix it.
see the diagram attached.
2helpful
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
30helpful
2answers
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
