Heating & Cooling Logo
j
jamie green Posted on Dec 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG Gold window a/c unit W18TKM not dehumidifying the air - no water coming out the external hose, any ideas?
Todd B
Level 3:
Master:
  • Master 572 Answers
  • Posted on Dec 07, 2013
Todd B
Master
Level 3:
Master:
Answers
572
Questions
0
Helped
165735
Points
1123
Check the pressures of the refrigerant...sounds like it is low which means there is a leak that needs to be located & repaired.
3 Related Answers
bobicehouse
Robert Moller
  • 1524 Answers
  • Posted on May 29, 2010
SOURCE: water coming through indoor unit
Clean drain.
Anonymous
  • 15935 Answers
  • Posted on Sep 04, 2010
SOURCE: window air conditioner cools but doesn't dehumidify
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Sep 30, 2012
SOURCE: Blows very cold air during dehumidify mode.
se this fact: God bless you
air conditioning system cools but does not dehumidify the room. The most common cause of inadequate dehumidification by an air conditioning system is the installation of a cooling unit which has too much capacity, or is "over-sized" for the space it is being used to cool. What happens is simple:
If an air conditioning compressor unit is oversized (too many BTUH of cooling capacity) what happens is it cools the room so quickly that the system does not move enough total volume of air across the cooling coil to remove much moisture before the room temperature has dropped to the A/C cut-off point.
In other words, an air conditioner needs to run longer, and move more total volume of air through itself to drop room humidity than it does to just cool the air. So "bigger" cooling capacity or higher BTU capacity for an air conditioning system is not necessarily better, and it can actually be a problem.
My lg dehumidifier lhd45et8 does not gather water,it appears that an external hose was connected at one time and i don't know ifa piece was taken out to connect the exteranl hose and how do I get it...
If you are not getting water at all then the hose is not the issue...
If you are getting water and it is just not going into the bucket, then plug the hole were the hose hooked up with silicone caulk and a plug fashioned out of whatever you can find that size...
If there is no water, then the compressor has a freon leak or is bad and the dehumidifier is junk... it will not be worth fixing it as cheap as new ones are...
heatman101
There was a build-up of a snotty white substance in the hose which blocked it from draining. Any idea what this substance could be?
That is an Algae that will grow in damp places... like the dehumidifier hose...
No major problem... just clean the hose with fresh water or replace the hose...
heatman101
The unit runs continusly and no water comes from the hose
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
My Whirlpool Gold dehumidifier is making the circuit breaker switch off. I used the sweeper to clean all of the dust from the vents but it continues to make the breaker switch off.
Take the unit outside and wash the coil out with a garden hose. Careful not to get water on the controls. Water will not hurt the motor or compressor as long as you keep it unplugged. Allow the unit to completely dry before running it again.
Discharge air is HOT!! - not cool
A Dehumidifier will not cool your basement, just make it seem cooler at the same temp. Your dehumidifier may be undersized even for that purpose.
You need an AC outlet of a central AC in your basement, or a window unit if there are windows.
Warm air at discharge is normal.
LG 65EL water not dripping to bucket
THE DRAIN LINE IS CLOGGED TAKE OFF THE HOSE FROM THE UNIT AND BLOW AIR BACK THRU THE UNIT,, IT IS NOT UNDER A PUMP SYSTEM IT IS GRAVITY, IF IT WON'T DRAIN IT'S CLOGGED
Brand New De-Humidifier not pulling water into bucket or hose !
I have lost my manuel. I do not know how to use the hose for when I go away for a few days.
1helpful
2answers
Draining Problem
Mine had the same problem. Make sure the unit is tilted towards the side with the hose attached (hose side low)
Top Goldstar Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
