Motorola Mobility RAZR V3c Cellular Phone Logo
M
Marilee Breeze Posted on Dec 02, 2013
Transferring pictures from a device
I need to know how I can down load my pictures from a sims card using the item I mentioned
i_sell_cell
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Jun 10, 2014
i_sell_cell
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
1786
Points
36
Your pictures are not saved to a sim card.
1 Related Answer
Anonymous
  • 32 Answers
  • Posted on Aug 22, 2008
SOURCE: Address book on SIM card
You can connect it to a pc via the usb port and transfer all of it into the computer. Some programs actually allow you to see the screens of the phone on the pc so try that out.
Can't get pictures off of my camera
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
1helpful
Pics wont down load to PC
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device, you can then open the folder on the memory card andcopy the photos to your computer.
How to down load pics from LG cell phone to Windows
Because I run Linux on my computer I could not run the software that came with my KC910. I was able to transfer my pictures using a bluetooth connection but it seemed to take forever. I purchased a bluetooth connection device that just plugs into a USB port.
What I do that works fine for me is to place my pictures on the SIM card and transfer them that way. Just get a USB SIM card reader and plug it into your computer. It will act just like another device and you can copy, edit or do whatever from there.
Hope this helps.
Also have a blackberry phone.Problem I do not know how to set up my GPRS settings and all other settings like,downloading,Email,etc. The camera also wont take pictures when I try to. PLEASE HELP...
To be able to use WAP, Internet browsing, MMS, Email you need to subscribe for BlackBerry data plan for your phone. BlackBerry is not like other phone that can work with the above mentioned features only if the GPRS setting can be put in place. BlackBerry device work with a special APN called blackberry.net which need to be assigned by your carrier (done by provisioning) in your SIM card. Except that there is no other way of using BlackBerry for above mentioned features.....
Card reader full on FinePix F30
connect the camera to your computer with the supplied USB cable.
On your computer (Windows) - select START and then Computer.
You will see all of the storage and media players devices attached/in your computer.
Click on the highest lettered drive (J, K, L, etc) until you get the one that shows that you are looking at the camera storage card.
Since the SIM card in your camera is like a hard drive, you can select items to move or delete or add to the SIM card. You can select all of the pictures on your SIM card and drag them to a folder on your computer desktop. AFTER that is done, you can select the pictures on your SIM card again and press Delete on your keyboard.
By the way, the pictures are in one of 3 folders on your Camera's SIM card, you will have to open the folder to see the pictures that are stored inside.
ALL OF THE ABOVE ASSUMES THAT YOU HAVE NOT INSTALLED THE SOFTWARE FOR YOUR CAMERA ON YOUR COMPUTER. If you have installed the software for your camera, all of the above is automatic when you plug your camera into your computer.... simply select the box labled "delete after transferring".
2helpful
2answers
I do not know how to hook up my camera to my computer to download pictures can u help i need to know if i have the right charter to use on my dock to load pictures. thx
I understand you?re interested in transferring the pictures from your camera to your computer. Please follow the following steps 1: Connect the camera to the computer using the USB cable, U-8. 2: Turn the camera on 3: A window will automatically appear on your display. Please follow the steps given to you by the programme. If no window appears: 3: Go into my documents 4: Find the location of the camera and your pictures 5 Drag and drop from the camera to the computer
1helpful
Sim card slot on my toshiba satellite will not upload pictures
Check the card with another computer or using the camorra with card inserted.
This lets us know the card is working and will store information.
If the card checks ok, then go to the Laptop and look in the device manager for flags, while camorra is hooked up and turned on.
If you find flags, remove them and reload drivers.
9helpful
3answers
Transferring pictures from phone to memory card on htc touch pro
I know this post is old but the easiest way to do that is to go into FILE EXPLORER.. and find your PICTURE folder it will show you all the pics on the device tap one of the pics once and drag down until all pics on device r yellow then tap and hold until menu pops u tap COPY once u have them copied as one file go back into MY DEVICE and find STORAGE CARD scroll all the way to the bottom then without touching another pic already there tap and hold the blank bottom then click PASTE and wait all pics will be transferred
TRANSFERRING DATA
To do this kind of transfer you would use the old phone sims card or memory card to save to the new phone. Another way is to sign in to you cell phone provider website. From there you may be able to download all your items to your new phone. From the computer to the phone wirelessly. You may need their customer service help to guide you thru the steps.
Artgirlny
3answers
Numbers transferring
Check if ur phone have one option SEND ALL VIA INFRARED OR BLUETHOTH!
Nov 15, 2007 • Nokia 1100
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
 Mikey
Mikey
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
