DISH Network ViP 612 Logo
A
Anonymous Posted on Nov 30, 2013
Dish recvr 612
Flashing picture
tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 • Televison & Video
My VP 612 will not give a signal to the 2nd TV. We had a have a VIP 211 and it works fine.
Hi there Rick, my name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to help you. A VIP 612 is a single receiver, meaning it can only control one tv independently, if you do have a second Tv connected it is mirrored correct? (meaning it watches/shares the same programming as the main TV connected directly to the receiver) If so, the TV connected with RG6 cable must be on channel 3 in order to receive a picture. Feel free to reach me at: [email protected] if you have any additional questions or concerns.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Satellite Receiver to Yamaha Receiver
I've just experienced the same thing with a new Pioneer VSX-820-K receiver
tip
DISH VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
tip
DISH VIP612 Amplifier Control
DISH Solo DVR VIP612 Amplifier / Receiver Control
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control the volume of your receiver, tuner, or stereo instead of your TV's volume?
The first step in using the Universal Remote Control that came with your Dish Solo DVR VIP 612 to control the volume level of your receiver, tuner, or stereo is to program the remote to control your audio device using the AUX mode button.
Once your remote controls your audio device in AUX mode, you probably want to continue to control the volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish Solo DVR VIP 612 Universal Remote to control the volume of your stereo regardless of which mode it is in, follow these steps:
  1. Press and hold the AUX button until all the mode buttons are lit, and then let it go.
  2. Press the POUND (#) button.
  3. Press the PLUS side of the VOLUME button.
  4. Press 0.
  5. Press the POUND (#) button. The AUX button flashes three times to tell you the programming is complete.
  6. Confirm the VOLUME buttons are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's volume should change rather than your TV's volume.
Your Dish Solo DVR VIP 612 Universal Remote is now setup to control the volume of your stereo regardless of which mode it is in
I hope that helps.
on Jul 05, 2010 • DISH Network ViP 612
It sounds like either on the 612 or the Yamaha Receiver that the HDMI port is faulty, thus causing the flashing picture. It sounds like the 612 to the TV works fine. I would recommend replacing the Yamaha, and if problem persists then try replacing the 612.
tip
I hope that helps.
tip
I hope that helps.
tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
tip
DISH Solo VIP612 DVR Quick Reference Download
Download DISH Solo VIP612 DVR Quick Reference Guide
Would you like to review the features of the DISH Solo DVR VIP612?
Have you lost your DISH Solo DVR VIP 612 Quick Reference Manual?
Would you like a digital, searchable, pdf version of the DISH Solo DVR VIP 612 Quick Reference Guide?
Follow this link (& click FREE) to download a pdf version of the DISH Solo DVR VIP 612 Quick Reference documentation.
I hope that helps.
on Jul 04, 2010 • DISH Network ViP 612
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
