Mitsubishi WS-55511 55" Rear Projection Television Logo
D
Daniel Downey Posted on Nov 24, 2013
What is the system restore and how can i replace it
ASC Computer Services
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Nov 24, 2013
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
2093
Points
39
System restore is usually a software function (although some devices have the ability to do a system restore from a button somewhere on the device - check / download your user manual for specific details.
As for replacing system restore, in short, you cannot. System restore takes an item back to factory state and even if you could you would not want to replace this.
Please help me factory reset my dell inspiron 6400 it's won't do it cause it tells me it is in safe mode how do I fix it
Krystal spears,
Below is information to restore your system using PC Restore. If the image is corrupt or you have formatted the hard drive you will have to manually reinstall Windows, Drivers and Software.
PC Restore
Use Dell™ PC Restore to quickly and easily restore a system to the factory image. PC Restore is not meant to replace normal troubleshooting steps. It is meant to be used only as a last resort when troubleshooting a system.
An image of the system is created at the factory and stored on a hidden partition. To start the application, press <Ctrl><F11> when the blue bar with "www.dell.com" is displayed during the boot process. PC Restore only takes a few minutes to restore the operating system.
WARNING:
Using PC Restore removes any software or data files loaded onthe system. Be sure to warn the customer before starting PC Restore.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
tip
WINDOWS XP SYSTEM RESTORE
System Restore is a tool that takes your computer back to a previously working state. This option is available in Windows ME, Windows XP and Windows Vista. Windows takes snapshots of critical system files, program files and registry settings and stores them as "Restore Points". If ever you should have any problem with your computer, you can "restore" your computer to one of these Restore Points, when your computer was working fine.
Please remember - System restore does NOT have any effect on your personal files such as emails, documents or photographs.
HOW TO USE SYSTEM RESTORE TO RESTORE WINDOWS XP TO A PREVIOUSLY WORKING STATE
In order to perform a System Restore, you must have administrative rights in your computer. If this is your own personal computer, then chances are that you will be having administrative rights in it, however if you are on a network computer, say for example in a computer at your workplace, then you will have to request your Network Administrator to help you.
In order to restore Windows to a previously working "Restore Point" follow the steps given below:
1. Log on to Windows with administrative rights.
2. Click Start, go to All Programs, go to Accessories, go to System Tools, and then click System Restore. System Restore starts.
3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
4. On the Select a Restore Point page, click the most recent system restore point and then click Next.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
6. Log on back to your computer. The System Restore Restoration Complete page is displayed.
7. Click OK.
If you have successfully restored your computer to a previous state, and the computer is performing as it should be, you can stop here.
But if the restore process completed successfully and the computer is still not performing as you want, you can either restore your computer to a different restore point or just undo the current System Restore. In order to undo a System Restore, please continue reading.
HOW TO RUN SYSTEM RESTORE FROM THE COMMAND PROMPT?
Many times, you may not be able to run System Restore because your computer will not start up normally. But you can still run System Restore from the command prompt.
  • Click on Start -> Run -> and type in %systemrestore%\system32\restore\rstrui.exe and click OK
OR
  1. Start up the computer in Safe Mode or Safe Mode with Command Prompt
  2. At the Command Prompt type %systemrestore%\system32\restore\rstrui.exe
  3. You can replace %systemrestore% with C:\Windows, if you like
  4. You might have to select the Operating System in your computer
  5. You might also have to enter your username and password
  6. You should have Administrator Rights in your computer to do this.
HOW TO UNDO A SYSTEM RESTORE:
You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
5. Logon to the computer as Administrator. The System Restore Undo Complete page appears.
6. Click OK.
You can now run System Restore again from a Different Restore Point.
on Jul 06, 2010 • Computers & Internet
Windows cannot find
will the computer boot to an operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
If this fails you might use the system restore option
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Ps3 says hard file disk corrupted and has to be restored but it just keeps doing this and has restored like 15 times and has not fixed itself. what can i do
1. Restore File System
Enter Safe Mode and select "Restore File System". "Restore File System" will attempt to repair damaged files on the hard drive. If this does not work, try the next step.
2. Rebuild Database
Enter Safe Mode and select "Rebuild Data Base". "Rebuild Data Base" will erase messages, playlists, changes made on [Information] screens, trimming information for pictures in [Photo], video thumbnails, video playback history and video resume information. Then attempt to rebuild the PlayStation 3 database. The content that is erased will not be recoverable. If this doesn't work, try the next step.
3. Restore PS3 System
Please note this will erase all content on the hard drive and will not be recoverable.
Enter Safe Mode and select "Restore PS3 System". "Restore PS3 System" will restore the default settings and will format the hard drive. If this doesn't work, try the next step.
4. Re-seat the hard drive
If you have replaced the hard drive in the PlayStation 3, make sure it was installed properly. If the hard drive is not seated correctly, it may cause problems.
5. Try another hard drive (if possible)
There may be an issue with the hard drive that is installed. Try replacing the hard drive with another one.
Windows won't start and I get the following: Windows could not start because of an error in the software. Please report this problem as: load needed DLL's for kernel.
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps:
  1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  2. Type the following command(sfc /scannow), and then press ENTER.
If this could not resolve the issue, Please perform system restore: Follow the steps below, Click on start- all programs- accessories- system tools- system restore.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure below, and then click Next.
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
After reviewing the stability of your system, you can choose another restore point or undo this restoration. Just open System Restore and make the appropriate choice. After you use System Restore, you'll have an additional task, Undo my last restoration, on the System Restore Welcome page. Remember that you'll have to reinstall any programs that were installed after the restore point.
If System Restore doesn't work in Normal Mode, it might work in Safe Mode. To use System Restore in Safe Mode, press the F8 key during reboot and choose Safe Mode. When your computer starts in either Safe Mode or Normal Mode, System Restore can be used to capture a working previous state. System Restore can't be opened unless the system is bootable into one of these modes.
Regards,
Yateesh Varma.
2answers
I downloaded windows media player 11 on the net. Unfortunately the original media player in my system was replaced with this only for me to dicover that the windows media player 11 I downloaded cannot...
Perform a System Restore to restore the Computer when it was working normally.
Check this link to perform the System Restore operation:
http://support.microsoft.com/kb/306084
Or
Click on Start -> All Programs -> Accessories -> System Tools -> System Restore -> Select the Restore date -> OK to perform the System Restore.
NOTE: The System Restore procedure will restore the Registry and other settings back to the date and time selected. No data will be lost. Saved documents and e-mail will not be affected by performing a System Restore. Any Hardware or Software that has been installed after the date of the restore point will need to be reinstalled.
Also scan your Computer for any virus infection.
Good Luck!!!!!!!!!!!!!!!!
3answers
Need to find solutions!
Through the All Programs menu:
1.
Click Start.
2.
Point to All Programs.
3.
Point to Accessories.
4.
Point to System Tools.
5.
Click System Restore.
6.
Follow the instructions on the wizard.
Creating a restore point can be useful any time you anticipate making changes to your computer that are risky or might make your computer unstable. If something goes wrong, you select the restore point you just created and Windows XP undoes any system changes made since that time.
Create a Restore Point
1.
Open System Restore. (See step-by-step instructions above.)
2.
Click Create a restore point, and then click Next.
3.
In the Restore point description box, type a name to identify this restore point as seen in Figure 1 below. System Restore automatically adds the date and time that this Restore Point is created.
Figure 1. Creating a restore point
• To finish creating this restore point, click Create.
• To cancel restore point creation and return to the Welcome to System Restore screen, click Back.
• To cancel restore point creation and exit the System Restore Wizard, click Cancel.
To view or to return to this restore point, from the Welcome to System Restore screen of the System Restore Wizard select Restore my computer to an earlier time. Then select the date you created the restore point from the calendar in the Select a Restore Point screen. All of the restore points you created and you computer created on the selected date are listed by name in the list box to the right of the calendar.
Note System Restore does not replace the process of uninstalling a program. To completely remove the files installed by a program, you must remove the program using Add or Remove Programs in Control Panel or the program's own uninstall program. To open Add or Remove Programs, click Start, click Control Panel, and then click Add or Remove Programs.
2answers
My usb ports dont work
hi dear
1.
Click Start.
2.
3.
4.
5.
6.
1.
2.
3.
oke
cropp
Sound
hi dear
1.
Click Start.
2.
3.
4.
5.
6.
1.
2.
3.
oke
cropp
My sound
hi dear
1.
Click Start.
2.
3.
4.
5.
6.
1.
2.
3.
oke
cropp
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
