SOURCE: kodak 5300 won't print black.did
i have had the same problem. This seems ot be a common issue with this printer. None of the local office supply stores carry printheads, you have to get them from kodak.
SOURCE: Printer Kodak Easyshare 5300 Will not print black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
SOURCE: printer does not make black
Close the printer.
SOURCE: kodak 5300 first said error 3802 now says print head missing or loose
Yeah I tried all of the things imaginable but it still will not print black... it prints color but not black.
SOURCE: Printer not printing black ink.. beware the clowns below with spam phone numbers
The problem you are all having is with the print head (The black tray that your ink cartridges sit in).
Most of the time a simple cleaning of this will correct the problem, if it does not then you will have to call Kodak support and they will send you out another print head.
But lets try and see if we can get your troubled one to work again by following these steps...
1 - turn printer on and open the lid as if you were going to change the printer ink cartridges.
2- when the ink tray moves into the center and stops, remove both the black and color cartrdiges from the print head.
3- To remove the print head simply place your left thumb inside the head all the way to the left facing up and pinch the upper left lip of the print head to release it, then pull the entire tray out with your other hand ( there is a release inside the tray above the sticker of a finger and bullseye to the far left in the upper left corner inside the tray)
4- With the tray now removed be sure to look at the bottom and you most likely will find a build-up of black ink... clean this off using DRY paper towel as much as you can.
I used rubbing alcohol but if you do this make SURE it is completely dry before reinstalling.
5- Once you have cleaned the print head reinstall it in reverse fashion than you removed it, if you installed it right you will hear a solid CLICK noise.
6- replace the ink cartridges you removed if they still have ink in them and then close the printer lid.
7- You may get a notice that there is a new printer head and or cartridges and it will want to align and or calibrate the printer...be sure to do this!
8- Once the printer is recalibrated hit the menu tab on the printer and choose " clean ink head"... Do a deep cleaning 2 times!
9- Now try to print something that contains something black like a text document. If it works you are all set, if it did not then you will need a new print head from kodak. simply explain that you did the above steps and it did not work so that you can avoid support trying to run you through all this. They will send you a new one in 2 days.
Hope this helps and good luck!
