Message loads at the bottom of the page and flickers lick crazy. I have it marked that when open the message will be in a new tab. That works but when I go back to the inbox, a message is always loading and flickering. I have tried the safe mode - it still flickers. I have tried a new download and install and it still flickers. Any idea's?
SOURCE: I can't open messages in hotmail
I had the same problem not a long ago..I have IE7. if you don't make sure you upgrade to Ie7 at least as it should.
things you need to try: (try in this order and test after trying one at a time)
1. clear cookies, temporary internet files, browsing history
2. update java
3. reset internet zone security to defaults
4. disable filter phishing and test.
5. disable pop up filter
6. tried to add following sites to trusted sites:
https://*.msn.com
*.hotmail.co,
*.live.com
*.passport.com
7.disable add-ons you may not need.
8. check you antivirus!! and scan your computer.
9. switch to firefox and if it works in firefox.. you may need to reinstall ie.
good luck!
SOURCE: Vista Home won't boot
NeoSmart Technologies offers a download called Vista Recovery Disk in .iso format. Download and mount the iso with your favorit burning program. Boot to the cd to access the recovery center. Hopefully you'll be able to repair your Windows Vista installation or restore to a known good configuration.
Good Luck
SOURCE: Flicker every 60 sec in Win Media Center TV mode
go to HP.com and look for the TV tuner upgrade. See if that solves your problem. Let me know
Thx
SOURCE: error R6002 floating point not loaded
Causes of Runtime Error R6002
Several causes exist behind this error. One of the most prominent ones is a broken link. This link apart from causing the run time error 06002 can also produce other errors like the computer not responding to any instruction at times. If a software has not been properly installed it can also produce such errors. Apart from that, use of internet without any anti-virus software can make your computer applications get infected with spyware and viruses. Such viruses can produce missing links inside your registry causing such errors.
Why are these errors caused? Many computer users are just not aware of the reasons resulting in these errors and what are the solutions to get rid of these errors. Remember, these errors can be solved very simply, and they are not going to cost you money. Usually many people exercise the option of getting professional technicians to resolve these problems. But this is not necessary. Through following the simple procedures suggested below you will be able to eliminate the error r6002.
If you take time and start noticing, you will find that the runtime errors are due to corrupted or damaged registry. You must know that the registry is the most importance place which is a storehouse of all the data, about both the software and hardware installed in the PC. When you uninstall software or remove a device there may be some traces of such actions left in the registry and manually it will be impossible to remove them. You should be having knowledge of computers to do this, since it is not advisable to access the registry without this knowledge and manually delete these files. A wrong move can result in damaging the PC irreversibly.
Therefore the only method to fix the runtime error r6002, along with many other errors, you should use the registry cleaner. With a registry cleaner you can repair the runtime error r6002 all by yourself, without seeking help of technician. This way you can save money and time, and you will also know the action to be taken next time when you encounter such errors.
Using the registry cleaner should be optimized with the antivirus cleaner, and if you program in such a manner that both the virus scanning and registry cleaner can take place simultaneously, for which purpose you should schedule these activities on the computer, and ensure that at that particular time the computer is switched on, without your botheration of checking them, they will do their job on their own, leaving you to attend to your work.
http://www.registryfix.com/?hop=reviewb
