both of you should have a gps capable mobile for a start,then you must configure both mobile to authorize to track each other,software can be downloaded in many website for free.
<p>Once I explain how Bluetooth GPS receiver to connect from a
mobile phone. Bluetooth GPS Receiver is a device that continuously transmits
its position (longitude, latitude and speed) using the Bluetooth protocol. If
your phone is Bluetooth-enabled phone, you can connect to a Bluetooth GPS
receiver to determine its position. To locate, connect to Bluetooth GPS and
mobile phone to get the NMEA sentences for location tracking, you can also
program a Java (J2ME) for your phone. Your program should do the following
tasks: <br />
<p><br />
<p>1. Bluetooth device within the search area. Each time a
Bluetooth device is discovered, discovery listener device Discovered trigger
procedure. In the search is completed, the trigger listener discovery process inquiry
Completed. <br />
<p><br />
<p>2. Get the name Bluetooth. We have a choice to a group list
of Bluetooth-friendly name of the devices found to store. We also need a vector
to devices found to store. <br />
<p><br />
<p>3. Select Bluetooth GPS receiver from the list of found
devices. <br />
<p>4. Find service by the GPS device. Bluetooth GPS Receiver
provides an L2CAP service so that the program needs to find this service for
GPS url connection string for. <br />
<p><br />
<p>5. Get connection string from the GPS device. Connection
string to the URL will have this format Url = "btspp: Address / bluetooth
/:" + + L2CAP_UUID "permission = false; encrypt = false"; <br />
<p><br />
<p>6. Sign up and receive sentences from the GPS device. After
plugging in the url in step 5, you can open the connection and extract
sentences from the connection string. <br />
hi,
GPS is present but not enabled on these phones when they come from the store. In order to activate the GPS it depends on your cell provider. Currently sprint has a update that will give you windows mobile 6.1 and GPS, but Verizon does not have a official update for their phones yet
Since the phone worked before the visibility issue is unlikely to be the cause. Try plugging your TomTom into your computer. In the my tomtom software, select manage my TomTom. Now find and select the item about mobile phone settings and delete it. That should fix the problem when you next ask the TomTom to set up a connection with your phone.
Garmin will work with ANY windows mobile device with built in GPS and or a bluetooth receiver. But you have to have the correct software there are 2 versions both will install but only one will work with your model phone for older model phones use version 4.10 or lower for newer model phones use version 5.0 or higher.
Let windows manage your GPS ports do not try to set it manually. If you have a GPS fix option...go out side where you can get a satellite fix easily...launch your GPS fix program...thenlaunch Garmin. It should connect and you will have to do this only once. I know from experience and I've use this on a T-Mobile Dash with a bluetooh adapter with no issues. I'd try a different receiver preferably any PharosGPS receiver.
1-First switch off u r mobile plug out battery/ sim card,than plug in batery /sim card than try
2-Contact LG care center , so that they format u mabile
