Tom Tom One 3rd edition. Tried the reset button tried holding the on button for 20secs,let it discharge and charge again but will not start up. It appears to be trying but the screne keeps flashing.
You will probably find that your internal BATTERY is now well past "its useful lifetime" [around 2 -3 years plus]. The same thing [and symptoms] happened with my 10 year old TOMTOM OneXL.
I was quoted $80.00 [by TT here in Australia] to possibly fix it + the cost of the battery ???
SO I purchased a new TT Via 280 with LIFE-TIME FREE MAPS for just over AU $240.00 ... Works GREAT and better maps as well !!!
SOURCE: tom tom one not turning on used 3 months
I had some problems with the 920. It started to not turn on. The it just died completely. After opening the case and testing the battery. I concluded the battery was dead and Un-chargable.
Which is most likely the case with yours.
Try this first. Then contact customer support.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
If your device uses an SD card, remove it.
Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
Press the On/off button for at least 5 seconds.
If your device uses an SD card, insert the SD card
Unless you are good with electronics. Then id change the battery myself. I used a cell phone battery.
It has worked for the last year.
Regards and I hope this helped.
James
Sketchlab.com
SOURCE: tom tom go 510 Sat Nav
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your computer
True
True
0
95250
95250
via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup
True
True
0
95250
95250
you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
SOURCE: When I bought my sat nav Tom Tom version 3 it
move the receiver to a different part of ther car if your car's windscreen is coated windscreen
SOURCE: My Tom Tom stopped speaking
1/probably it;s muted pull up the menu tap change preferences and tap turn on sound if not go to volume preferences
