Won't boot up the start up is missing
SOURCE: Dark Screen Inspiron 9100
If you replaced the inverter board and its still dark you need and new backlight itself http://cgi.ebay.com/LCD-Backlight-Lamp-for-Dell-Inspiron-9100-15-4-WXGA_W0QQitemZ150217509448QQcmdZViewItem
SOURCE: Dell inspiron xps 9100 cpu upgrade
Highest compatible cpu for your system is the Pentium 4 3.6 ghz Prescott. Hope this helps & please rate this solution fixya. Thanks.
Here is a link to a spare parts supplier for your system: http://www.dellweb.co.uk/spares/inspiron/9100.htm
SOURCE: Audio Driver needed for Dell Inspiron XPS 9100
Found a way : download http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R78742&formatcnt=1&libid=0&typeid=-1&dateid=-1&formatid=-1&fileid=103937
Execute and it wil create a folder un c/:dell/
Next ask to update the audio driver and choose this folder. It dit then the job automaticcaly and it now works great.
Good luck
SOURCE: dell inspiron 1501 won't boot
Caps lock flashing indicates faulty memory - it's a POST (Power On Self Test) before BIOS executes. When memory is removed it should indicate "no memory". Carefully re-insert the RAM memory module, check the tiny contacts inside the connector on dust. Then try again.
If there are 2 memory banks (1 one the back, the other under keyboard) remove one RAM memory module.
If capslock keeps on flashing test it with another RAM module.
SOURCE: Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
