20 Most Recent Dell Inspiron 5150 Notebook Questions & Answers
Dell Inspiron 5150 - says user profile service failed the logon. user profile cannot be loaded.'
You have a corrupt operating system use your windows disk to do a repair.
11/2/2017 9:36:22 PM • Dell Inspiron... • Answered on Nov 02, 2017
2answers
Laptop freeze when in ac charger
You really should have a cheap multimeter to help in this case.
There are three possible failures; the new battery pack has a shorted cell, the charger is defective or a regulator internal to the laptop is failing.
With meter, you can check two of the three areas; the battery pack and the charger. Depending on which kind of batteries are used in the pack, if it is charged, you can determine if it is completely functional by checking contacts on the case of the pack. The most common type of battery used is the nickle-metal hydride type (NiMH) which has a nominal voltage of ~1.2 volts.  If the pack is rated 6 volts, you could measure either 4.8, 6 or 7.2 volts with the last one the most likely. If it measures 4.8 or 6 volts, it probably has one or two cells shorted, making it useless.
The charger could measure all over the map; many of them are unregulated and if they are rated at (for example) 9 volts, they could easily put out 14-20 volts when they do not have a load on them.
If those two items seem to check out OK, then the regulator in the system has gone bad. This might be on a separate board inside but to check it out, you really need some technical experience, otherwise you don't really know what you are seeing or looking for.
12/30/2016 6:34:37 AM • Dell Inspiron... • Answered on Dec 30, 2016
Base system device driver
It is a driver for your card reader. Check the driver on your manufacturer's website usually on the support section.
8/10/2014 10:08:49 AM • Dell Inspiron... • Answered on Aug 10, 2014
DELL INSPIRON WILL NOT ACCEPT WINDOWS 7 i GET ERROR n0_MORE_IRP_STACK_LOCATIONS
Was the hard drive contain any previous operating system? If it was, then you need to chose "Delete the volume" and "Format", and let's see the result after you reinstall the Windows 7.
3/12/2014 6:22:28 PM • Dell Inspiron... • Answered on Mar 12, 2014
I bought a computer nd the person that had it
You need to be specific where you need the password. Are you asking about password on Logon screen when your PC boots up? Are you asking about a WiFi network password? Any other type of password?
11/1/2013 9:23:15 PM • Dell Inspiron... • Answered on Nov 01, 2013
Hi there ..my dell inspiron laptop making horrible siren frequently during startup or when i attached the pendrive..what is the problem??
It could be the CPU fan with worn bearings.It could be the CD/DVD drive but only when the laptop boots up.Connecting a USB pendrive should not start this noise as there are no moving parts in the pendrive.
4/17/2013 4:24:20 AM • Dell Inspiron... • Answered on Apr 17, 2013
My Dell inspiron 5150 wireless card locks me out..When I can get it to unlock I can go on the internet for a while and then it will kick me off.A message comes up saying more then one wireless connect
Tim Mckibbin,It might be the router causing this to happen. I would try updating the firmware on the router to see if this will help. Also make sure that it is your wireless and not your service provider. Try to hook the modem up without the router and see if it drops. If it is the router, you might want to change it.At the link below is the Dell Networking Support Center.Dell Networking and Support CenterThank You,Dell-Jesse LDell Social Media and Communities
2/7/2013 1:26:43 PM • Dell Inspiron... • Answered on Feb 07, 2013
How to unlock my 5150
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
12/1/2012 7:29:40 AM • Dell Inspiron... • Answered on Dec 01, 2012
No power battery flashes 4 orange
If it is orange or is blinking orange, the battery charge is low or expended. Remove the battery and re-install it. Plug in the AC adapter and connect it to an outlet. Turn on the computer. When the battery status light blinks green and orange, the battery temperature is too hot for charging. Shut down the laptop, detach the AC adapter, and allow the laptop and battery to return to room temperature before attempting to charge the battery. If the battery status light blinks orange rapidly, the battery itself may be defective.
4/10/2012 6:16:25 AM • Dell Inspiron... • Answered on Apr 10, 2012
Power on and Battery led's
WHEN U POWER THE POWER LED IS GREEAN ???IF NOT HAD PROPLEM WITH CONNTROLER OF POWER HAVE SOME HAD TO POWER
3/21/2011 2:42:50 AM • Dell Inspiron... • Answered on Mar 21, 2011
My computer has all the lighrs blinking can not
Needs Charging?
2/22/2011 6:57:46 AM • Dell Inspiron... • Answered on Feb 22, 2011
Can i upgrade my Dell 5150 pci to a gigabyte port?
It is definitely possible to change the ports by soldering a new gigabit chip on the motherboard, but it is a serious task your board may lose its life if anything goes wrong...
on the other way you can use a serial to ethernet converter, if you have a serial port on your laptop....
there is no USB to gigabit converter available in the market (so need not search for one)...
2/4/2011 1:11:15 AM • Dell Inspiron... • Answered on Feb 04, 2011
I am trying to use
Hi, I understood that you are trying to use dell laptop with verizon wifi. but may i know what exactly is the issue that you are facing ?
I'll be more than happy to help with more explanation :)
11/2/2010 6:49:33 AM • Dell Inspiron... • Answered on Nov 02, 2010
My laptop will not run with power cord and the
All you need is a new replacement battery. The old one has a dead cell that will not let current flow through it causing this warning for you
7/15/2010 12:30:00 AM • Dell Inspiron... • Answered on Jul 15, 2010
2answers
Some of the keys on keyboard stopped working
Yes replace the keyboard. It is usually not a hard job so have a look here < LINK
Best of it.
Thanks for choosing Fix Ya
5/29/2010 7:18:52 AM • Dell Inspiron... • Answered on May 29, 2010
When i plug the charger into my dell 5150 the
Try a different AC adapter, if no change the charger unit on the motherboard is bad
5/11/2010 8:42:17 PM • Dell Inspiron... • Answered on May 11, 2010
Dell Inspiron 5150 Notebook Logo
78 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
some keys keyboard stopped working
  • Computers & Internet
