Here is how to remove ignition lock:
Rotate ignition lock cylinder to RUN position. Using a 1/8-inch drift, depress lock cylinder retaining pin through access hole and remove lock cylinder.
Carefully NOTE: the position of the bearing retainer prior to removal.
Remove blue plastic bearing retainer by inserting a screwdriver or similar tool, with a 90 degree bend on the tip, between bearing retainer and bearing and by prying upward.
Insert tip of a screwdriver into Double-D slot of bearing, then rotate 90 degrees. Remove bearing.
Remove lock drive gear. Carefully note relationship of lock drive gear to position of rack teeth.
Here is the installation:
Position lock drive gear in base of lock cylinder housing in the same position as that noted during removal procedure. The position of lock drive gear is correct if last tooth on drive gear is meshed with last tooth on rack.
Position bearing retainer in lock cylinder housing. Insert tip of a screwdriver into Double-D slot of bearing, then rotate 90 degrees.
Press blue plastic bearing retainer into lock cylinder housing. Ensure retainer is in its original position.
Line up flats of drive gear with flats of washer by pulling down on the column lock actuator.
Install lock cylinder assembly.
Check for proper start in PARK and NEUTRAL. Also, check to ensure start circuit cannot be actuated in DRIVE or REVERSE positions and the column is locked in LOCK position.
Notes:
There is an access hole is from the bottom - you can see it from underneath, you need to push a pin up on it to release the luck cylinder.
You don't need to change out the bearing or anything else other than the cylinder. With the new cylinder in hand you will see what I mean.
Good luck and hope this helps
Where is the lock release retaining pin located for 94 Lincoln town car
SOURCE: Remove and Install Headlight Switch in 1994 Lincoln Town Car
Disconnect the battery ground first
1. remove the trim strip from the left and right of the steering assembly
2. take the 12 screws that hold the dash panel
3. take a right angle tool and remove the headlight switch knob by inserting in slot at the back of the knob and pulling toward you and pulling the knob off , this will let you pull back the dash panel and expose the switch. Un- fasten the headlight switch bracket and un fasten the connector and inspect . Replace the switch if necessary , especially if it is burned. GOOD Luck
SOURCE: heater core
bad news for you because you may have to take the dash apart on the pass side to pull heater core a shop wasnts about $600 in labor but it can be done i did on my 1993 good luck
SOURCE: 98 lincoln town car won't start. fuel pump
the enginr oil pressure switch runs the fuel pump till the oil pressure is up to the normal operating range. When the pressure is up the relay kicks in and takes over the power to the pump. The oil pressure switch my be at fault if you can no hear the pump running when you turn the key on
SOURCE: How do you replace an ignition switch on a 96
is this a key switch or the electrical actuator
SOURCE: 2003 Lincoln Town Car - Power window switch removal/installation
SECTION 501-05: Interior Trim and Ornamentation
2003 Town Car Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 01/28/2002
Front Door Trim Panel Printable View (206 KB)
Removal and Installation
NOTE: LH side shown, RH side similar.
Open the screw covers.
Thanks for the information and help you provided.
