Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
Posted on May 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know oil/gas mixture for husqvarna chainsaw
I bought a used husqvarna 340se 16'' chainsaw and I need to know the proper oil to gas mixture ratio. Anyone able to help me?
  • Anonymous Mar 17, 2014
    husqvarna 440 chainsaw oil pump
J. Bradshaw
Level 2:
Sniper:
  • Expert 121 Answers
  • Posted on May 05, 2009
J. Bradshaw
Expert
Level 2:
Sniper:
Answers
121
Questions
Helped
87686
Points
323
40 to 1 is the ratio.
  • Stephen Peter Ross
    Stephen Peter Ross Oct 30, 2014
    Once almost ubiquitous, the 1-in-40 oil-to-fuel ratio has fairly well, long since gone be the wayside for high performance saws, includingg Husqvarnas. For one, the greater compression and high-output made possible by special additive 50:1 oils has made possible lower capacity, lighter weight saws that are more amenabe to purchase and use by the general-comsuming public. Where 40:1 is still mfr recommended or supplied, it will be with lower-grade, non-high-performance saws. Now we have a 17 helpful, consensus answer.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 06, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7213
Points
Husqvarna recommends a 50:1 for all of their chainsaws as well as their "LS" (Low Smoke) chain oil which has special adhesion additives. 40:1 will not hurt much but will results in increased smoke and plug fouling--and not provide any extra engine protection.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on May 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
18889
Points
16
All the Huskies I've had have been 50:1. I'm pretty certain the 340 is as well.
Bear Creek Lodge
Level 1:
New Friend:
  • Posted on Sep 17, 2013
Bear Creek Lodge
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7213
Points
Huskies require 50:1 however, they also say to add some oil to the mixture, which really makes it 40:1.....also use 93 0ctane always.Regardless, I also add Sea Foam to all of my small engines and 700cc UTV.
Stephen Peter Ross
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 181 Answers
  • Posted on Oct 30, 2014
Stephen Peter Ross
Expert
Level 2:
Mentor:
Answers
181
Questions
16
Helped
71928
Points
511
BEAR IN MIND...that while Hooskies are characterized for 1:50 oil:fuel ratio that does not mean any 2 stroke oil at 1:50...ONLY 1:50 labeled oil. If available, you must purchase oil clearly labeled 50:1 (fuel:oil--or 1:50 oil:fuel).
Other mix ratios are, in fact, possible--in a pinch--but always follow the mix instructions on the oil container up to the maximum fuel:oil (or miniumun oil:fuel) mix ratio advised by the saw mfr.
The saw owner manual gives preferred and alternative-mixture-ratio oils that can be used. That will be a general rule of thumb for all saws with the exception that you must never under-concentrate the oil to fuel ratio that is recommended by the saw manufacturer. That means, for example, that 1:50 characterized saws, like the Hooskie, have the greatest leeway, being able to use 1:50 oil and everything of higher oil concentration: such as 1:40. However, a saw characterized by mfr for, say, 1:40-labelled oil may not use 1:50 oil mixed in fuel at 1 part per 50 oil to fuel ration--its fuel must be mixed 1-in-40 parts oil-to-fuel...even if only 1:50 labeled oil is available.
In mechanics terms, oil-to-fuel concentration is a function of piston (ring) to cylinder clearance tolerances: greater clearance requiring more concentrated oil to fuel; "tighter" toleraces requiring oils able to withstand the stresses of lower concentration. As a consequence, for example, a modern "Hooskvyarna", with its low clearances for high compression, operates optimally at the 1:50 lube concentration. It will work with a more concentrated lube ratio, but not as efficently or powerfully due to the greater drag and lower compression associated with the more concentrated oil-fuel blend.
Need to know the ratio of gas and oil for gas chainsaw 435 16' Husqvarna
Use a ratio of 50-1 with Husqvarna two stroke oil, with other two stroke oils they recommend a 25-1 mix as they do not know the quaility of other manufactureres two stroke oil, always try to use Husqvarna oil.
Fuel mixture for a Husqyarna E-series 137, mod/137802010
The mixture should be 50-1 with Husqvarna rwo stroke oil, it is recommended that you use a mixture of 25-1 with other brands of two stroke oil, this is because they do not know the quaility of other brands, always try to find genuine Husqvarna oil.
2answers
I need to know what the gas to oil ratio is for a Husqvarna 372xp chainsaw is
Hi gducci1949...
Use a 50 to 1 mixture...1 pint of oil to 6 gallons of gasoline
Please take time to rate me
What is the gas to oil mixture for the Husqvarna 340 Chainsaw
The fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil available from home centers, hardware stores, and saw dealers. Premix in it's own container with fresh fuel and be sure to shake the container thoroughly just before you fill the tank each time to prevent oil starvation. Hope this helps!
Ratio for gas mixture
The ratio is 40:1. Use good quality 2 stroke oil, preferably Husqvarna, not the type you can get at car service stations as the cheaper oil will cause the engine to wear more quickly.
What is the mixture of oil and gas
Husqvarna recommends 50:1
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
2helpful
Gas Oil Mixture
Fuel Mix: Add 6 oz. McCulloch custom lubricant or 1 PT. S.A.E. 40 (16:1) to 2 U.S. Gal. Regular Gas
2answers
Ive just bought a husqvarna 34 husky is this the model number 34? its serial number is 016810 but i cannot find details of it anywhere an want a manual can you tell me mixture also its my first chainsaw,...
Get Chain lube for the chain oiler. Naturally, husqvarna recommends that you use "genuine husqvarna" oil for your mixture, I recommend a quality oil, doesn't have to be husky. Husqvarna recommends a 50:1 ratio, other manufacturers, of vertually all 2 cycle power equiptment use a 40:1 ratio. This mixture is slightly richer, but will not hurt your chainsaw. May produce a bit more smoke. Not sure what a 34 husky is...neither is Husqvarna, I visited the website and even tried to download a manual. Looked at every husky model, no 34.
2helpful
Chainsaw gas/oil mix ratio
I have two Stihls that are well over 20 years old. I use the factory recommended mixture, 1 part 2 cycle Stihl oil to regular gas. (1:50)
That is still what the factory recommends. Don't use a cheap 2 cycle oil, go to a Stihl store and buy their 2 cycle oil in the orange plastic bottle.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
