Looks like the problem is not the speaker is the microphone. You need to go to Control Panel then Sound and click on Recording tab.You need to be able to see the Microphone setup, you need to configured it. Good luck!
Well if you can hear RS then take it to your local electronics repair store if warranty has expired.
If you cant hear RS aswell then you might not have the right number of speaker's or speakers setup right. if you have 7.1 then you will have LS and RS speakers if it is 5.1 setup then then rear speaks have an option on most to be a rear (behind speakers) or rear (side speakers
The person I am speaking with does not hear me (He is deaf). The microphone function does not appear to be working. I have adjusted
the volume and that's not the problem (You must speak as well). I have plugged both jacks (microphone and speaker) into my PC hard drive
and am using my PC to talk on Skype (You cant plug even a single jack in the hard drive). Problem solved!
check your audio settings TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. To set webcam mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays Restart computer CONFIGURE TO CHAT PROGRAM
if you cant hear caller voice. do one thing go to gallery and go to voice recorder and record some voice then save that then go to media and play recorded sound if its working means your loud speaker is working but not ear peic means (ear speaker) not working. so then you need to change ear speaker.you can do your self just watch video on online.
Sound inducers do go bad. Normal the same audio amplifier is used for both the ear piece and the speaker. Since the speak does work, it sounds like the ear piece has died.
hi im josh a mobile phone technician in cebu phils, may i help you? Friend if that would be your prblem that your speaker won't work then that is very simple.A speaker is a hardware in the cellphone that cannot be damage easily but always be foreseen as damage because it is very sensitive especially when the phone was dropped. Friend the problem of your speaker is only a disconnection the filament of the speaker to the board is disconnected or misaligned. all you have to do is firmly screwed the phone properly and dont use casing the may tighten very much your phone coz this may cause disconnection.just tighten firmly correctly the screw of the phone.it will solve the problem. good luck. vote me so that i will know if i helped you so.thanks
