My kitchen breaker blew. We reset the breaker but fridge is not working. The front digital display box on the fridge door seems like its locked up or something. All the dashes are lighted up but it won't let me change anything & I don't hear a fan or compressor running. Is it fried???
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
SOURCE: Kenmore fridge compressor not going on - reset circuit breaker?
Look at item 4 on this picture for location of the defrost timer. You will need to rotate it with a flat head screwdriver and you should hear a click to see if your compressor starts. On the first picture above about 0.5 inch from the top from the 12 o'clock position is the dial that you will need to rotate It should be mounted horzintally in the top of your food section. The dial could be white or black. It has 2 tabs on it and can only be rotated in the direction that the tabs would be engaged by a flat head screwdriver. Turning it backwards will result in having to replace the defrost timer straight away. So again rotate this dial and see if your compressor starts.
http://images.google.com/imgres?imgurl=http://www.appliancepartspros.com/sect/b/u/1/bu16zh5hjj.gif&imgrefurl=http://www.applianceblog.com/mainforums/whirlpool/14104-whirlpool-freezer-evaporator-freezin-over.html&usg=__XxMLJp3a6BBih2eOJKB6x3mtNqk=&h=939&w=680&sz=45&hl=en&start=6&um=1&tbnid=qKT0RbtaUM62dM:&tbnh=148&tbnw=107&prev=/images%3Fq%3DDefrost%2Btimer%2BDial%26hl%3Den%26safe%3Doff%26rls%3Dcom.microsoft:en-ph%26sa%3DN%26um%3D1
If it starts then you have either a bad defrost timer or 60 deg F thermostat in the freezer section coils.
If it does not start then you can have a bad compressor relay, run capacitor or the compressor itself has failed. If the compressor is hot and you hear a hum from the compressor for about 30- 45 seconds it could be any one of the 3 above.
I would be willing to go out on a limb here and say you most likely have a defrost circuit problem.
There is a remote possibility that you had a one time instance of the defrost timer sticking but on an older unit If it stuck once it will most likely stick again in the future.
Update: My fan & compressor are working as everything is still cold in fridge and frozen in freezer today. But the digital box on the front outside door on my fridge is still not working. All the dashes are lit up but I still cannot make any adjustments as it seems to be locked. Can anyone please help me to fix this problem?
