Motorola Mobility RAZR V3 Logo
Marilyn Barlow Posted on Oct 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting started I just received a motorola ritr cell phone and when I=my battery charged up it pop up I have 2 messages, but I can't for the life of me understand how to retrieve my messages. Please help me.
Anonymous
Level 3:
Brigadier General:
  • Master 7,752 Answers
  • Posted on Feb 15, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
7752
Questions
Helped
1416233
Points
13016
Is this voicemail or text msg......if it is your VM system you can press and hold the 1 keypad and it will automatically dial your vm then just follow the prompts.
If it is text msgs just press the menu key in the middle of the keypad scroll to msg and read from your inbox.
My h17 only holds a charge for 2 hours. can the battery be replaced
Unfortunately, the Motorola H17 does not have a user replaceable battery. The battery is supposed to last the life of the product and can only be removed by breaking the headset. If the battery fails (leaks or will not charge beyond 80%) while the headset is under warranty (1 year from initial purchase), then Motorola will replace the H17.
See page 2 (page 4 of the PDF) of the manual for the battery removal information. See page 26-27 (pages 28-29) for the warranty information. I found a PDF of the H17 manual here: http://pdfstream.manualsonline.com/3/3a6e954c-6f97-45d3-b9f1-4643d8bad313.pdf .
I hope this helps.
Jul 24, 2017 • Cell Phones
2helpful
2answers
Motorola Fire XT (XT530) charging problem .
Motorola FIRE XT Tips for extending battery life
Back to Previous Page
Are there any tips on how to extend the battery life?
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tips:
  • It may take several charging cycles for your battery to reach optimum performance.
  • The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
  • You can charge your phone via USB cable but this charging time will vary based on computer specifications.
Tips to extend battery life:
  • Select a shorter backlight duration
  • Lower the display brightness
  • Use the AC adapter to charge your phone whenever possible
  • Turn Bluetooth off when not in use
  • Turn Wi-Fi off when not in use
  • Close any third party applications running in the background
  • Playing music, videos and viewing images in your phone will affect your battery life
General Battery use & safety
  • Motorola recommends you always use Motorola-branded batteries and chargers. The warranty does not cover damage caused by non-Motorola batteries and/or chargers.
    Caution: Use of an unqualified battery or charger may present a risk of fire, explosion, leakage, or other hazard. Improper battery use, or use of a damaged battery, may result in a fire, explosion, or other hazard.
  • Your battery can be charged without it being fully depleted, and can be charged every day if desired.
  • Battery usage by children should be supervised.
  • Important: Motorola mobile devices are designed to work best with qualified batteries. If you see a message on your display such as Invalid Battery, Invalid Charger or Unable to Charge, take the following steps:
    • Remove the battery and inspect it to confirm that it bears a Motorola "Original Equipment" hologram;
    • If there is no hologram, the battery is not a qualified battery
    • If there is a hologram, replace the battery and retry charging it
    • If the message remains, contact a Motorola Authorized Service Center
  • New batteries or batteries stored for a long time may take more time to charge.
  • Charging precautions: When charging your battery, keep it near room temperature. Never expose batteries to temperatures below 0°C (32°F) or above 45°C (113°F) when charging. Always take your mobile device with you when you leave your vehicle
  • When storing your battery, keep it in a cool, dry place.
  • It is normal over time for battery life to decrease, and for the battery to exhibit shorter runtime between charges or require more frequent or longer charging times. Motorola batteries are designed to last between 350-700 charge/discharge cycles at room temperature. This amounts to approximately a year to a year and a half of battery use for most people.
  • Avoid damage to battery and mobile device. Do not disassemble, open, crush, bend, deform, puncture, shred, or submerge the battery or mobile device. Avoid dropping the battery or mobile device, especially on a hard surface. If your battery or mobile device has been subjected to such damage, take it to a local service center before using. Do not attempt to dry it with an appliance or heat source, such as a hair dryer or microwave oven.
  • Use care when handling a charged battery-particularly when placing it inside a pocket, purse, or other container with metal objects. Contact with metal objects (such as jewelry, keys, beaded chains) could complete an electrical circuit (short circuit), causing the battery to become very hot, which could cause damage or injury.
1helpful
2answers
Why would a daily recharge be needed?
Because it isn't made of the best battery cells,there may be some memory effect with it.Get more tips for prolong battery life.
The phone is only 4 months old and it just died. It will not turn on. have charged it.....no signs of life. Taken the battery out and put it back in.....still dead. It was fully charged when it died.
before this thing happen, is there any sign or pop message coming out your phone, "memory full, delete some data"
try to remove your memory card first then try to ope it again
Have Motorola W 220. My phone suddenly switches off. When i try to restart, it starts for only a few seconds. The phone is showing message "invalid Battery' or "No battery". When i try to charge the phone...
cleen the charging tips & battery connector carefully,some times the moisture placed on it after cleaning try to switch on.if the problem not gone.than u have 2 choice 1-buy a new battery and test it and go to the phone repair shop who take some general cheking on it.
2helpful
Motorola w220 invalid battery problem
you better change the battery and dont recharge too. charge daily per hour
Battery not holding charge
That sounds like typical battery life for that phone.  When I owned one that's what I got on the weekends when my call volume was lower.
1helpful
2answers
2answers
L6 won't charge
If u r not able charge u r battery , than change the charger , contact motorola care center.my be u r not getting power supply in mobile
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
