20 Most Recent
Motorola Mobility BT50 Cellphone Battery Questions & Answers
How do I backup contact phone numbers
Hi Jeremy,
In this link Moto Phone Portal Backup Restore Contacts you will find the step to backup your contacts.
Regards,
Maya
Motorola Support Team
1/6/2020 4:45:08 AM •
Motorola...
Answered
on Jan 06, 2020
Unlock Blackberry
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website
Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
2/12/2014 3:48:50 PM •
Motorola...
Answered
on Feb 12, 2014
Code defalt
I do not understand your description "code defalt" what exactly is the issue you are facing?
10/15/2013 10:11:32 PM •
Motorola...
Answered
on Oct 15, 2013
White screen
This can be a failure of the LCD screen and so it is needed to counter check before it is confirmed.Sometimes a fault in the strip can also cause this fault or even faulty components in the display driver section.Take consensus and estimate.
12/14/2011 5:15:27 AM •
Motorola...
Answered
on Dec 14, 2011
I have a motorola crush and my charger worked fine
sometimes any motorola phone will give you this message. The phone will still charge but it has to be powered down to charge.
Sometimes turning it off, plugging in, and then powering on will help reset the phone.
3/18/2011 1:42:43 PM •
Motorola...
Answered
on Mar 18, 2011
My phone wont charge
Try to remove the battery and put it in a similar phone, charge with your charger, if it charges, it means the charging port of your phone is bad and will need to be replaced.
But if the charger did not charge your phone, it means the charger is the problem.
You can also use another charger to charge your phone to see if it will charge it, if it does not, it means the problem with your phone is the charging port.
Replace it and your phone will charge.
Take care.
4/22/2010 12:12:44 PM •
Motorola...
Answered
on Apr 22, 2010
Sim Network Unlock Pin Motorola
How to enter my Unlock Code on Motorola ?
Model : All Motorola
1 - Switch ON your phone with a not allowed SIM Card,
2 - Phone show "Enter Special Code",
3 - You can now enter the Unlock Code we send to you.
WARNING : If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody allready enter too many wrong codes, you just have to let phone ON on theses errors messages and after 40 min to 2 hours maximum the message "Enter Code Special" will appear again !
https://www.unlockbase.com/faq/en/Q_47.html
How to change IMEI number please?
The IMEI number can never be 'changed' It is the unique identifier that identifies your phone from every other phone in the world. It is on your phone and no one else's.
The number is hard wired into a chip and protected against being altered by people who have sold or received stolen phones.
3/27/2024 11:51:35 PM •
Cell Phones
Answered
14 hours ago
