I have a Toshiba TV/ VCR/ DVD player combo. One day the DVD player stopped working, There is a disc in there, but you cant get it to play or open to get the disc out. AND you cant shut the TV off ( either by remote or on the TV buttons) you have to unplug it... Only thing that happened recently is we hooked up a Wii or my son (17months old) did something ..he loves buttons. Any help would be much appreciated. Thanks
You can try leaving the television unpluged for a couple of days and see if letting the circuits completely discharge will let the television reset itself to normal operation. You can also call Toshiba customer support and ask them if this problem is common and if there is a simple solution. The customer service telephone number is 1-800-631-3811. Give them the model number of your television and they will help you. I hope this information help you with your problem.
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, aMotorola cable
box, and an RCAVCR.To control devices other than the default brands,performthe
following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insertmedia (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume,andVCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
Repeat steps 1 through 5 for each device you want to control.
[^] For future reference,write down each working device
code
OK.
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
applicable, insert media (e.g., cassette or disc).
[2] On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
selection, volume, and DVD functions.
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
[5] Aim the remote control at the device and press POWER
[6] Repeat steps 1 through 5 for each device you want to control.
code
OK.
