You should have had in the box with your Surface 3 Tablet a charger. It will have a plug with 2 points that is for your power plug, and at the other end you will have a natty little flat magnetised plug for the side of your Tablet. Mine is at the bottom right slot, looking at the screen of your Tablet. Now when the power is turned on, a small bright light will glow. That is now informing you that the battery in your Surface is being charged. Now at the bottom right of your Task bar, that is the Bar on the bottom of your screen where you can place program short cut Icons for your convenience. Now the speaker Icon which is there toward the right-hand side and has a cross if off, or a different look when on. Now the next icon on its right is the one that tells you how much charge is in the battery, if you touch it, it will come on to the screen informing you how much charge you have in the battery. If I'm using my Surface a lot and I do I keep it on charge while I work as a precaution to keeping my Surface well topped up. Hope this helps.
Two options in this case: get the tablet replaced, as the damage is internal, or find a certain way that your charger will work and charge it like that. In the second case it helps if you prop the charger under with an eraser or a piece of paper.
The Tablet should have a Icon, showing you Battery Life , (ie) how much you have left in battery . You can't over charge battery , as computer has safty cut off,
The mini USB cable that came with my tablet was lame and would only charge if held at a certain angle. Another cable worked fine. This is an ultra cheap tablet, and they cut corners everywhere they could.
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
