Dacor ECS230 Epicure Electric Double Oven Logo
g
g w hong Posted on Nov 06, 2013
Oven is dead
Power is on at the breaker switch.
hongster
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 6 Answers
  • Posted on Nov 06, 2013
hongster
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
6
Questions
0
Helped
10297
Points
11
Is it the entire oven or just the heating element?
Testimonial: "It is the entire oven, display included. I already checked the breaker, and it has power."
2answers
If you switch oven on it trips main power. what can cause that
Probably close to 50 things could cause that, but here are a few of the most common: Bare wire in a harness of the oven, causing a short-circuit in the line. Faulty plug on the power cord. Outlet in the wall is damaged. Loose wire in the outlet box, causing a dead short. Bad wire between the outlet box and the main breaker box. Weak breaker, or a breaker that isn't heavy enough to handle the load of the oven. (especially, if you just bought a new oven, it may need a larger breaker to handle start up.) Use a fused multi-meter (voltmeter) to check for these issues, and do not try to fix it if you are not familiar with electrical work. It could cause a fire, or give you a deadly shock.
Feb 12, 2017 • Ovens
Oven locked with door open how do I reset it?
my first thought is if the oven is standard 220 three or four prong electric, for safety, go to breaker switch panel,"in House or outside of house", open pannel door and find the breaker switch marked for "oven" or "kitchen utility" . it will be a double switch of 20 to 25 amp ,"each". or it will b One breaker switch of 45-50 amp. ,switch it to off. then see that the oven has no power, the stove top as well as the lights and the oven .try to unlock it now. by lever or button ? then if not unlocking turn the breaker back on and try it again. hope it works for you.
Mar 29, 2015 • Ovens
4helpful
2answers
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
1helpful
We had a power outage today during the self cleaning process of our double oven.. The Electronic Oven Control panel is dead. No lights of any kind. The circuit breaker is ok. Upper door is locked.
Turn the breaker off for 5 minutes. this will reset the system. If you still have no power then it spiked your control board and it's the board that is fried.
Please remember to leave rating before you sign off
No Power, DEAD
I would pull the stove back, first to check the plug, and then, the cord. If all is well, and breakers are good, you might need to call, then
Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
