SOURCE: Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
SOURCE: I have a maytag stove
I have a Maytag stove Model #MER5875QCW The problem is it
Takes for ever for the stove to reach 350c Can anything be done?
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
SOURCE: electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
SOURCE: Electric stovetop gets VERY hot
LIFT TOP FROM FRONT ABOVE OVEN DOOR. TURN OFF POWER BEFORE SEVICING.
