SOURCE: I need a printable manual for an edu science mobile telescope.
Very had to find a manual for these small telescopes--
Meade telescopes a large manufacturer, maintains a web site with manuals for all of their telescopes. Look through the ones on this web site and download the manual that most closely matches your telescope.
http://www.meade.com/manuals/index.html
maybe this manual???
http://www.meade.com/manuals/TelescopeManuals/Polaris/Polaris60AZ_AR.pdf
SOURCE: edu science reflector telescope instructions 600x
This is a small refractor telescope-- they pretty much all work the same-- BUT don't expect to get more than 100 power out of the scope. Yes I know the box said 600 power but it's a lie. In my 8 inch telescope I rarely get above 250 power and my scope is many times larger than the one you have--
Now put the eyepiece with the largest number written on it into the telescope-- the LARGER the number the LOWER the magnification. During the day time practice focusing on a distant object --- AND line-up the small finder scope on top with the main telescope tube. Look at the top of a distant light or church steple, or telephone pole. Without moving the telescope adjust the small finder scope by loosening and tightening the screws around the tube holding the finder scope-- put the crosshairs on the same spot as the main telescope.
Now you can use the small finder to locate objects in the sky-- the moon should be your first night time target.
SOURCE: when I look through the telescope all I see is black
Basics first - please don't get angry at the suggestions ......
1) On the main telescope, can you see the actual glass lenses at both ends of it (i.e. you've removed both of the lens caps).
2) If you remove the eyepiece (in broad daylight), can you hold it up to an indoor light and see clearly through it?
3) If you now look into the socket where the eyepiece goes, can you see any form of light (in daylight) or is it totally black?
A lot of smaller telescopes have caps both ends, and sometimes caps both ends of both parts, to stop debris getting in when in transit or swapping objectives.
SOURCE: need a manual for a 525x edu science reflecting
You will not find one for this scope that is sold by Toys R Us.
Sorry, we receive more complaints about this scope than any other. Read my TIPS on my profile page.
SOURCE: manual for an edu science telescope F=700mm
You will not find a manual for that telescope which is sold by Toys R Us. However Meade and Bushnell both maintain web sites with all of their telescope manuals--- here:
http://www.meade.com/manuals/index.html Meade manuals
http://www.opticsplanet.net/bushnell-warranty.html Bushnell
Look around the web sites under the REFRACTOR heading for one that is similar to your telescope. They all assemble and are used the same way.
Read my TIPS on my profile page and also read this web site:
http://www.texasastro.org/telescope.php
