The
security system does not disable the starter, it only disables fuel to the
engine. In the fuse block under the hood, locate the STARTER relay. Place your
hand on this relay and see if it clicks while someone else turns the key to
start...if the relay is ok then the starter itself is faulty. Good luck, i hope this helps.
The alarm sounds when one of the temperature sensors inside the computer detects a temperature higher than "allowed". This usually means that one of the fans inside the computer has failed, reducing the amount of "air-cooling". Check that the fans are spinning, at their correct speed, and replace any "dead" fan.
If there is no original remote try to find a switch that may be hidden but accessible from the drivers seat, if the alarm is no longer needed find an auxilliary wire that may be on the battery or the fuse panel, if original there may be a fuse under the hood, pull the fuse and it should disable the alarn system.
