Hi there
The front panel connectors are
mainly,
- harddisk activity connector
- power switch connector
- reset switch connector
- power LED connector
- speakers connector
- USB
connector
Harddisk activity connector
This normally comes red in colour and is labeled
as HDD-LED
Power switch connector
This comes green in colour and is labeled as
POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled
as RST-SW
Power LED connector
This is usually green in colour and is labled as
PWR-LED
Speakers connector
This speaker will give different beep sounds
during boot to tell the user if there is any errors. It
occupies 4 pins, however only 2 is important for the
function. Be sure to connect the red coloured cable
to the positive polarity and the black to the
negative.
Front panel connectors pins on the
motherboard
Front panel connectors from the
casing
Good luck and thanks for using FixYa!!
There is no sequence. With power off connect them where they go. Note that if any of the LED's don't light up when they should, you need to power down and reverse the plug for that LED on the pins.
Or is it where to plug them in that is what you need to know?
Look closely at the printing on the motherboard. There are a bunch of pins sticking up that are where the connectors go, and what they are for is usually labeled right on the motherboard, or perhaps on a label that was provided with the board.
