I've read your owners manual online and found nothing on changing the water level-I did read that there is a procedure to add an extra rinse cycle to the each washing-here is the link to the owners manual http://www.productsmanual.com/read/whirlpool-pdf-wfw9750ww01-duet-automatic-washer-owner-s-manual.html-cheers Denny
SOURCE: i have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
SOURCE: replace the bellow in my front loader whirlpool washing machine
Hello.
You don't need any special tools to do this. Feel around the edge of the bellows seal until you find a spring in the groove behind the face of the seal. Using a small screwdriver, lever it over the edge of the seal, and slowly work the ring over the seal face. Peel the seal off of the mounting flange, and roll it inside the drum. Remove the front of the washer, and remove the spring on the inner part of the seal. Replace the seal, making sure that it is oriented in the same manner as the one you took off. Reassemble in the reverse order. There are a number of very good videos on YouTube. Type in "washing machine repair" and you'll find different chapters in what amounts to a series on repair.....good stuff.
Hopes this is helpful to you.
Best regards, --W/D-- please feel free to rate this carefully hand crafted answer! Thanx!
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
