yeah i bought sony hndy cm hdr cx210e but when i play back in my com it gets choppyyeah i bought sony hndy cm hdr cx210e but when i play back in my com it gets choppy
You can't post conmments that contain an email address.
<p>Equipment needed <br />
<p> <br />
<p>
<ol>
<li>PC</li>
<li>Analog Capture Card (you can find prices here)</li>
<li>Sound card (some capture cards has their own audio input)</li>
<li>Cables</li>
<li>VHS Player/Camcorder</li>
<li>Capture Software (Windows Movie Maker 2 can do this)</li></ol><br />
<p><br />
<p><br />
<p><br />
<p><br />
<p><br />
<p>Steps to perform<br />
<p> <br />
<p>
<ol>
<li>Hook up your capture device to your computer</li>
<li>Turn on your PC, install the drivers</li>
<li>Hook up your analog player to your capture card with the
cables</li>
<li>Load your capture software</li>
<li>Set the capture options (video and audio)</li>
<li>Start the capture process</li>
<li>Start the playback on your analog device</li>
<li>Once the analog device has finished, press stop</li>
<li>Stop the capture process</li>
<li>Save the video</li></ol><br />
<p><br />
<p><br />
<p><br />
<p><br />
<p><br />
<p><br />
<p><br />
<p><br />
<p><br />
<p>Remember, you capture card merely records the signals that
comes from you analog device. If the footage is blurry and choppy, it's
probably because of aged tapes or dirty video heads.<br />
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback. Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder. Hookup between TV, DVD recorder and VCR is completed. Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV. Hope this info will help you.
Having used a cleaning tape several times to no effect. I then went to record, to see if the bands appeared in recording mode. They didn't. So I went back to playback mode and the bands had disappeared.
This can be a bit of a tricky one to figure out. My initial response would be that you have another program or process that is causing your computer to play 'choppy' video. When you have a newer computer that was recently working just fine and now all of the sudden the video is choppy, it is usually due to another process using CPU cycles that are so important to video playback.
Start playing a DVD, but don't go to full-screen mode. Open the Task Manager. Right-Click on the task bar and select Task Manager. Click on the 'Processes' tab. There is a column labeled CPU, click on the heading 'CPU' twice. This will order the processes in order from highest CPU usage to lowest. The top two processes will most likely be your DVD player and the process that is causing your choppy playback.If the offending process isn't essential (i.e. anti-virus), then click on said process and then click the "End Process" button.
If the heads become dirty, “NEED HEAD CLEANING” appears during recording. During playback, moreover, the following symptoms appear. ≥Mosaic-like noise appears partially or the sound is interrupted. ≥Black or blue mosaic-like horizontal stripes appear.
When normal playback cannot be performed even after the head cleaning One possible cause is that normal recording could not be performed because the heads were dirty at the time of recording. Clean the heads, and perform recording and playback again. If normal playback can be performed, the heads are clean. Before an important recording, be sure to conduct a test recording to make sure that normal recording can be performed. ≥If the heads become dirty soon after cleaning, the problem may be the tape. If so, try another cassette. ≥During playback, the picture or sound may be interrupted momentarily, but this is not a malfunction of the Camcorder. (One possible cause is that the playback is interrupted by dirt or dust that momentarily adheres to the heads.)
I had this problem very recently. In fact I borrowed camcorders from my friends too and after short periods, they too started having the same problem. Essentially, it looks like there is some choppiness every second or so - like there is noise in the audio and video. After a lot of looking around, I finally found a suggestion posted that ACTUALLY WORKED on all 3 camcorders:
I placed an empty tape in the camcorder and recorded a few seconds into it. Then I removed that tape and tried to play the previous tapes that were showing the choppiness. No problems any more. Everything works fine.
What I still do not understand is why 3 camcorders (all DCR-TRV103s) all showed the same problem (with different tapes by the way). And since I still have lots of tapes to copy, I need to know why this problem is happening so I can minimize its occurrence while I complete the copying process.
People have suggested that my tapes are old and may be offering resistance to the camcorder. So I have ordered a rewinder to spin the tapes a bit before trying again. The two possibilities suggested around this was (1) some mechanical switching took place which got reset when recording; and (2) something got corrupted in the software that manages the playback buffer and that software was rebooted when it went to recording mode.
So while this will hopefully answer your question, I'm also looking for explanations for why this happened to me on 3 different camcorders.
