NetGear Universal WiFi Range Extender Network Adapter Logo
K
Karen Pushpa Posted on Oct 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Got a Netgear wifi extender but my current password won't work to access the new_ext network.......don't know what to do!
stephen Adams
Level 3:
  • NetGear Master 2,219 Answers
  • Posted on Mar 08, 2015
stephen Adams
NetGear Master
Level 3:
Answers
2219
Questions
0
Helped
355221
Points
22262
You need a new password to access the new wi-fi extender, you cannot use the existing router password.
1 Related Answer
Anonymous
  • 27 Answers
  • Posted on Aug 06, 2012
SOURCE: netgear wifi extender schematic
Look it up from the manufacturer
Comcast changed my wireless password and now my netgear extender doe not work
You will need to reconfigure your extender, check the manual or online at the link bellow.
Since your extender is not working your range is diminished.
WiFi Range Extenders
2answers
HOW TO ACTIVATE NETGEAR WIFI EXTENDER
In brief, all you need to do is to set your extender the same way your router is set, including WiFi IP, security type, wireless channel, password, radio type. You need to know your access IP by using network cable plugged into your extender to program it. Search the Internet for a manual. It should not take more that 5 min to do.
2answers
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
2answers
I ask to join and they ask for password and i typed in password and it will let me join
Try using the same security settings as your existing network by selecting the "Use the same security mode" check box when setting the your extender.
2answers
How to set up netgear ex6100 wifi range extender
  1. Plugin your extender in electrical outlet.
  2. Place your extender near your router when first time your are setting new extender.
  3. Launch any web browser and enter mywifiext.net. The New Extender Setup page displays.
  4. In the Password section, type the existing WiFi network password. Default user name is admin and password is password.
5. Click continue and a message box displays saying that your extender is connected to the new extender WiFi network
6.
Now, you can connect your device to the extender network, go to the WIFI settings and connect to the extender's new network.
7.
Netgear EX6100 Setup is successfully completed now place the extender at the desired location and enjoy seamless Connectivity.
Netgear ext
Once the range extender is in "discover" mode it will find your existing wireless network. It will then take the name of it and add '_ext' to it. giving you a second wireless network. For instance, if your wireless network was called my-house, the extender would create one called my-house_ext.
Password
  1. username should be admin and the password is password
45helpful
2answers
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
