Jamo I300 Docking Station Logo
B
Benayad omar Posted on Oct 20, 2013
Electrical drawing SCHEMA
SCREEN SCHEMA ISN'T RECOGNISED AS MINE.
Please don't type all in CAPS, it is considered SHOUTING and is harder to read.
Check out the link for password reset.
https://www.google.com/search?q=SCHEMA+PASSWORD+reset
tip
Electric schema for Galant 1994, 2,0 l, hatchback
Gentlemen! I need to understand my car.
2answers
Where is the flasher unit in the mazda soho 121
Wiring, schema tic, electrical diagrams, torq settings, parts info, error/fault codes, full assembly/dissembly, service instructions and a lot moreetc are basic contents of these online books they here on this website https://big-manuals.com/
11helpful
1helpful
Schema
In AD, the schema is the list of "properties", or attributes of each item an AD "object".
There are different object types - user, computer, group, and so on. Some properties exist for all objects - "name", "create date", etc. Other properties only make sense for certain objects - a user has a "phone number", but a computer object does not.
So the schema is a list that says what "object types" are defined, what "properties or attributes" are defined, and which properties are valid for which objects.
Schema classes and attributes
Every directory object you create is an instance of an object class contained in the schema. Each object class contains a list of associated attributes that determine the information the object can contain. Classes and attributes are defined independently, so that a single attribute can be associated with multiple classes. All schema classes and attributes are defined by the classSchema and attributeSchema objects, respectively.
Classes
ClassSchema objects are used to define classes in the schema. A classSchema object provides the template for building directory objects of that class. Examples of classSchema include User and Server. A classSchema object contains, among other things, the following information:
Class type (structural, abstract, or auxiliary)
Common name and Lightweight Directory Access Protocol (LDAP) display name
Lists of the "must contain" and "may contain" attributes for instances of the object
Relative distinguished name attribute
A list of possible parent classes
Class types
Three different types of classes exist in the schema:Class type Purpose
Structural
Used to instantiate objects (users, servers and so on) in the directory.
Abstract
Provides templates for deriving structural classes
Auxiliary
Contains predefined lists of attributes that can be included in structural and abstract classes
Attributes
AttributeSchema objects are used to define attributes in the schema. An attributeSchema object determines the allowable contents and syntax for instances of that attribute in the directory. Examples of attributeSchema include User-Principal-Name and Telex-Number. An attributeSchema object contains, among other things, the following information:•
Common name and LDAP display name
Syntax rules
Data constraints (single versus multivalued, minimum, and maximum values)
Whether and how the attribute is indexed
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
