Motorola Mobility T505 BLUETOOTH CAR SPEAKERPHONE BLUE TOOTH Logo
A
ALICIA Ulmer Posted on Oct 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Jensens bluetooth speaker wont turn back on
Sebe Christian
Level 2:
Sergeant:
  • Expert 401 Answers
  • Posted on Oct 20, 2013
Sebe Christian
Expert
Level 2:
Sergeant:
Answers
401
Questions
8
Helped
72882
Points
960
If it's battery operated, try charging the battery.
Can I pair my jam wireless speaker with my IPod Nano 7th generation?
no because the speaker wont connect or show on any ipods except forr the ipod touch
My jam classic wont go into pairing mode at all and my phone wont pick upat all
Make sure your Bluetooth is turned on on your phone. You may have to make it discoverable as well
I have a portable wireless speaker model AWSBT7 will not go into the connect mode when pressing the button to sync up device I do not get the two beeps or the light does not flash faster
Hi Jerry, Are you using this method to pair your device?
Pairing
The Bluetooth-enabled device that you wish to stream audio to your speaker system must
fi rst be paired to the speaker. The process is simple, and in most cases the pairing process
needs to be done only once.
To pair your Bluetooth-enabled device with the speaker:
1. Make sure your device's Bluetooth is turned on. See the wireless and/or network settings
menu on your device to check.
2. If the speaker isn't already on, press the On-Off button to turn it on. You will hear a beep
to indicate the speaker is turned on. The indicator light on the back of the speaker starts
fl ashing blue.
3. Press and hold for 3 seconds the Pair button to enter pairing mode. You will hear 2 beeps
to indicate pairing mode is entered. The indicator on the back of the speaker starts blinking
faster.
4. Open the Bluetooth settings menu on your device. Select "AR SPEAKER" from the list of
devices available (you might have to scan for devices). If your device asks for a password,
enter "0000".
5. A confirmation screen will appear on your device once the speaker and the device are
successfully paired. The blue indicator turns solid blue to indicate successful connection.
The speaker is now ready for you to stream audio from your device.
3answers
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
2answers
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
2answers
How do i sync my phone to my smps-650 wireless speaker
Turn on the Bluetooth
In Bluetooth Off mode, press and hold the Bluetooth button for about 5 seconds until a beep sound is heard and the Bluetooth button backlight flashes blue.
Press and hold the Bluetooth button for about 7 seconds to change to
Bluetooth pairing (linking) mode. The Bluetooth button backlight will flash blue and red. then go to the Bluetooth settings on your phone and select it there and enter 0000 for the default password
Then go to the bluetoothT
2helpful
3answers
Speaker wont connect to bluetooth
Go to your Bluetooth settings and forget the device. Then re-pair it for a fresh connection. This worked for me
2answers
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
2answers
Blue tooth speaker wont turn back on.
Unable to connect to a device?
Before attempting any of the following steps, make sure that you are running the latest software version on your SoundLink Wireless Mobile speaker. Click here to visit the software update center and update your speaker. If you are still having difficulty connecting to a device after updating the software, continue to the troubleshooting steps.
Unable to connect with a previously paired device?
Please try the following to resolve this issue:
Perform a product resetTo perform a SoundLink speaker reset, following these steps:
  1. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly
  2. Press Power to turn the SoundLink speaker back on
Clear the pairing list on both the SoundLink Wireless Mobile speaker and the source
  1. On the SoundLink speaker, press and hold the Bluetooth button for approximately 10 seconds until you hear a tone. The SoundLink speaker clears all Bluetooth devices from its memory and becomes discoverable
  2. Clear the list on your Bluetooth device. For more information, please refer to the manufacturer of the device
  3. Perform a product reset. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly. Press Power to turn the SoundLink speaker back on
  4. Try pairing the device again by following these steps:
    1. With the Bluetooth device and the SoundLink speaker both turned on, press and hold the Bluetooth button on the speaker for three seconds to make the speaker discoverable. The Bluetooth indicator will slowly fade on and off approximately once every second to show the speaker is in discoverable mode
    2. Set your Bluetooth device to "Discoverable." This will allow your device to discover the SoundLink speaker
    3. On your device, locate the Bluetooth device list. Select "Bose SoundLink" from the list
    4. If your device asks for a passkey, enter digits 0000 and press OK. Some devices also ask you to accept the connection. Your Bluetooth device indicates when pairing is complete. The SoundLink speaker indicates pairing is complete when the Bluetooth indicator stops fading on and off and remains on
Be sure the SoundLink speaker is within 30 feet of the Bluetooth deviceThe system is designed to operate at a range of 30 feet. However, performance can be diminished by obstacles such as walls or metal, and may also be affected by other Bluetooth devices. Try moving the SoundLink speaker closer to the Bluetooth device.
Be sure the source's Bluetooth function is OnMany Bluetooth enabled devices have an option where the Bluetooth feature can be turned On or Off. This option may be set to Off to save the battery life of the device. Be sure this option is set to On. If the Bose product is paired to the Bluetooth enabled device, it should automatically reconnect when its Bluetooth function is turned on. If the Bose product doesn't automatically reconnect, manually select the Bose product within the Bluetooth list on the device.
Manually connect the SoundLink speaker in the device listSome devices will pair to a device but not automatically connect. Go to the pairing list of the device and check if this is the case. If it is, try connecting to the SoundLink speaker.
Top Motorola Mobility Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
john h
August Brown
August Brown
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
