NEC AccuSync LCD72VX LCD Monitor Logo
Posted on Sep 24, 2007
Nec flat screen goes blank after 20 seconds
The screen goes blank after 20 seconds and will not come back on unless you turn off the computer. Could something be wrong with the cables?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 02, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
769
Points
I got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
3helpful
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4helpful
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
2answers
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
DiamondPoint V71LCD Not displaying image
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
