20 Most Recent
NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor Questions & Answers
I hooked my new computer
hi, hook up your old one and change the refresh rate to 60 or 70 hertz, go 2 display properties, then the settings tab, then advanced,then monitor. and set it as i said. turn off computer after you change settings. hook up the nec, you then should be good 2 go. good luck! and please rate this solution. if you need further help, reply.
Nec MONITOR TURNS ON FOR A SEC THEN GOES BLACK
This monitor is going into the protection mode due to a component
failure. The unit should be sent or taken in to a service center for
testing and repair. The NEC customer support telephone number is
1-800-632-4662. The website for customer support is
www.necdisplay.com/support center. They will be able to tell you where
you can take you monitor for servicing. I hope this information helps
you with you problem
I want to use a NEC Multisync 1700V monitor as an
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
NEC multiSync 1700V as external monitor for
Hi, if the 17 inch lcd screen is not a widescreen then the problem with the screen is possibly nothing more than the aspect ratio or resolution, which ever way you wanna look at it. All laptops have a widescreen type of ratio, so you will have to be either willing to change the resolution when you switch screens or setup different profiles, which you should beable to do through control panel, appearance and then personalization, you will then have access to it.
My monitor not stay on
Very common for this model that top backlight globe goes faulty.
Can be also inverter PCB fault.
If you have couple spare lights connect them to your inverter instead of panel lights and see if fault remains.
My samsung 731b lcd monitor blinks off and on
This monitor is going into the protection mode due to a component failure. The unit should be sent or taken in to a service center for testing and repair. The NEC customer support telephone number is 1-800-632-4662. The website for customer support is www.necdisplay.com/support center. They will be able to tell you where you can take you monitor for servicing. I hope this information helps you with you problem.
Need to take the back off the monitor to fix a part
Yes you will need a plastic putty knife or plastic pry bar . You need to find a open space put in the plastic and slide it up and down and around the edge to unlock the plastic locking mechanism that keeps the bottom and top of the monitor casing together. You must do this very carefully so as not to break the locks. If you do break some of the locks. You will have trouble keeping the case closed around the edges. To do this you need a large table space and you need to pad the surface. Place the face of the monitor down and work at separating the back from the front.It take patients. After it is done you will be able to see the power board and main board. They may be covered with a metal heat shield, that will have to be removed.Make sure you take notice of where the screws came from as they may be the only right screw for the hole. You should use anti static wrist bands and gloves to make sure you don't discharge static electricity in to the components on the boards, doing more damage. I hope this information helps you with your problem.
Dell laptop boots with only the external
there are buttons on the keyboard thay will have blue symbles on them and if you hold fn and press the button the screen will work again there will be a little screen on the buttone press that one
please rate my help to you
Monitor
Exactly what the one in my shop is doing and it turned out to be bad HV board in monitor.
Gary(Honkity Hank)
