Exercise & Fitness Logo
A
Anonymous Posted on Oct 08, 2013
Ntl09707.4 incline problems - NordicTrack Exercise & Fitness
My Reebok Jet 200 is stuck at an incline
If your Reebok Jet 200 treadmill is stuck at an incline and you are unable to lower the incline to the 0 position, there are a few things you can try to fix the problem:
  1. Check the incline motor and make sure that it is properly installed and functioning. If the motor is damaged or not functioning properly, it may be causing the incline to remain stuck.
  2. Check the incline control board and make sure that it is properly connected to the incline motor and other treadmill components. If the control board is damaged or not functioning properly, it may be causing the incline to remain stuck.
  3. Check the incline cable and make sure that it is not frayed or damaged. If the cable is damaged, it may be causing the incline to remain stuck.
  4. Check the treadmill's belt and make sure that it is properly aligned and tightened. If the belt is misaligned or loose, it may be causing the incline to remain stuck.
  5. Check the treadmill's power supply and make sure that it is properly connected and functioning. If the power supply is not functioning properly, it may be causing the incline to remain stuck.
If you have tried all of these steps and are still having issues with the incline on your Reebok Jet 200 treadmill remaining stuck, you may want to consult a professional for further assistance. A treadmill repair technician will be able to diagnose the problem and recommend the best course of action to fix it.
What is error code 53? Treadmill only working when incline is 0.5. When change up or down, it shuts down.
Error code 53 typically indicates a problem with the incline motor or the incline sensor on a treadmill. It could be caused by a malfunctioning incline motor or a problem with the wiring or connections between the motor and the sensor. The fact that the treadmill only works when the incline is set to 0.5 suggests that there is an issue with the incline mechanism and it may need to be serviced or repaired by a professional.
What if if dos noting but shows on the display servive 72
If your Nautilus T9.14 elliptical trainer is displaying the "service 72" message, it typically means that there is an issue with the incline motor. The incline motor is responsible for adjusting the incline of the elliptical, and when it is not working properly, the elliptical will display this error message.
Here are some steps that you can try to resolve the issue:
  1. Check the incline motor connections: Make sure that the connections between the incline motor and the console are secure and tight.
  2. Check for any debris: Make sure that there is no debris or foreign objects blocking the incline motor.
  3. Check the incline motor fuse: Make sure that the incline motor fuse is not blown and replace it if necessary.
  4. Check the incline motor itself: Make sure that the incline motor is not damaged or worn out, and that it is functioning properly.
  5. Contact the manufacturer: If none of the above solutions work, it could be a problem with the incline motor itself and it may need to be replaced. Contact the manufacturer's technical support for further assistance and they may have more specific troubleshooting steps to help you fix the issue.
It's worth noting that this error code is related to the incline motor, so the incline feature may not work and you may need to use the elliptical trainer without that feature until the problem is resolved.
2answers
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
2answers
Sportsart 3000 treadmill problems
ERR7 Definition: The display board main IC didn't receive the incline variable resistor (VR) value, or the value exceeds the set range. Explanation: The incline VR voltage changes as the incline motor operates, and the display board CPU uses the VR voltage to calculate the incline position. Without this value, the CPU cannot instruct the incline motor what to do, so ERR? appears. Or when the incline set is out of alignment, the VR value exceeds the set range.
The following is a list of possible solutions:
1. Incline Set a) Inspect whether the Incline ERR LED on the drive board lights. This LED indicates that the incline set has exceeded the range. b) Inspect whether the incline set mechanically exceeds range. On DC incline motors, at the 0% position, the line on the thin incline pipe will not align with the end of the thick pipe. On AC motors, at the 0% position, the red line will not appear even with the bottom of the incline window in the incline set. See Incline Troubleshooting Manual for details. c) Inspect whether the incline VR voltage exceeds the range: Put multimeter probes on the incline VR set blue and green wire connectors, while keeping the wires connected. Refer to Incline Troubleshooting Manual for the voltage range for your treadmill. If the incline range is exceeded, either mechanically or electronically, calibrate the incline set. Refer to the Incline Calibration in the Incline Troubleshooting Manual for directions. If the incline set cannot be calibrated electronically, replace the incline VA. If the incline set is stuck and cannot be unstuck, replace the whole incline set. 2. Drive Board Inspect incline voltage on the blue and green wires at the drive board. If voltage is within range, and ERRl appears, inspect drive board component connections and components for wear. 3. Ribbon Cable Inspect ribbon cable for breaks. Inspect connections at the display and drive boards. 4. Display Board Inspect IC connections. Push down to secure connections. Re-insert les.
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Is there an online repair manual for the Golds Gym Advantage Treadmill? I'm trying to solve an incline problem. The incline does not go up when I push the incline button. I just get a series of beeps...
Your owners manual describes how to perform an incline calibration. Here are the instructions.
Start the machine running. Press and hold the incline up button. While the numbers are changing, remove the safety key. Reinstall the safety key. The treadmill should rise to maximum incline, then lower to minimum. After completing the cycle, the treadmill should function correctly.
If not, you may have a damaged wiring harness (caused during assembly) or a defective incline sensor.
If the sensor is defective, you will need to replace the incline motor.
Top NordicTrack Exercise & Fitness Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
